Starter Wiring
Starter Wiring
I'm hooking up a new starter. Can someone confirm this is the proper connection?
1.) Small yellow wire from engine wiring harness to small post on solenoid (30).
2.) Large bundle of red wires from engine wiring harness to the longer post on solenoid (50).
3.) Black wire coming from front of car (battery) also to the long post (50).
4) Black ground wire from chassis to one of the starter mounting bolts under 10MM hex nut.
5) Nothing on solenoid short post that has a wire going into the starter.
