96 993 Fuse Box - What is this wire?
Can anyone tell me the purpose of this black wire coming out of this relay? In the next photo, note the date stamp on the fuse board.
Due to the neatness and care taken in potting the tapped in wire; I am left wondering if this is a factory fix or change from year 95 to 96?
Can anyone please shed some light on this?
Thank you in advance...
From the initial collective responses, I gather this may not have been some sort of factory fix for the 96?
Yes, as I previously indicated, the board has OBVIOUSLY been replaced since a date stamped board
(03/00) could not have been as installed from a 96 factory produced car.
The wire is fed across the top and under the baard and into a wire harness plug in the bottom.
I rectified the backwards fuse since it is wired to the flux capacitor which could result in catastropic time warp...Any serious ideas or thoughts would be appreciated...
this is likely for a kill switch from a car that was racing. It was very common to make a jumper into the relay to cut fuel or DME on the kill switch. I think I still have the same relay from my old setup before I added Motec.
As for the fuse, I just pointed it out since the rest of them were all oriented in one way very nicely. Someone made a joke of it and we had a bit of fun.
To my knowledge the car has never been raced or tracked, and no radar detector that I am aware of, is/was installed.
I laughed at the backward fuse comment, so it was taken with the same intent as delivered :-)
My real issue is an apparent short that affects the glove box light, trunk light, and ready state light for the immobilizer on the speedo. I am trying (unsuccessfully) to program additional immobilizer remotes as a backup to the one single working remote that I have. Without the feedback of the immobilizer light on the speedo, I don't know if I am being successful in the programming procedure.
Seems kinda stupid that such a significant feedback light is on the same circuit as insignifcant lights for glovebox, and trunk. :-(
I took a quick look at the fuse box in my race car. There are two relays setup this way. One is for the DME circuit for a kill switch and the other is as Mike suggested in R23 horn location. I think if you check the factory service bulletins you may find a dealer update was done to your horn circuit. Here is what mine looks like.
Thats gotta be it! Thanks so much for taking the time to pop your fuse cover and posting the pic.
I sincerely appreicate your help
Paul
I was looking at this old thread bc my car has the exact same white relay with a black wire coming out of it ..... The relay was a specual relay installed as part of a recall campaign in 1999 to prevent the airbags from going off inadvertently when the horn is pressed ...http://www.edmunds.com/car-maintenan...16&type=recall
Vehicle: 1996 Porsche 911
Recall Number:
98V089001 Dates Manufactured:
Nov 1995 to Apr 1996 Number of Vehicles Affected:
1968 Date Owners Notified On:
Feb 1999
Defect Description:
VEHICLE DESCRIPTION: PASSSENGER VEHICLES. INADVERTENT DEPLOYMENT OF THE AIR BAG CAN OCCUR.
Consequence of Defect:
DEPLOYMENT OF THE AIR BAG WITHOUT WARNING COULD CAUSE A DRIVER TO LOSE VEHICLE CONTROL INCREASING THE RISK OF A VEHICLE CRASH AND PERSONAL INJURY.
Corrective Action:
DEALERS WILL INSPECT THE AIR BAG SYSTEM AND A SPECIAL FILTER HORN RELAY WILL BE INSTALLED THAT PROTECTS THE AIR BAG UNIT FROM VOLTAGE PEAKS.
Recall Number:
Feb 1999
Defect Description:
Corrective Action:
