97 Turbo S - battery draw issue
Hey guys, a few weeks ago I posted a thread that my Turbo S wouldn't start ... many suggested the battery, but it was only a few months old and my dash lit up, alarm worked, etc... Well I eventually hooked up a smart charger to the battery and determined it would not hold a charge, fried. This was a factory battery from the dealer. So I just replaced it with a high end performance Bosch last week ... last night no crank ... so it became clear that I have a short or a draw. Took it to a buddy's shop today, not a Porsche mechanic. He applies basic troubleshooting and removes fuses 1 at a time with a meter attached to the battery and determines that a 7.5 amp fuse in slot 29 for ""Inside Lights Interior Sensor" is the draw. We removed the fuse as a bastardized solution until I have a chance to take it to a real Porsche mechanic or talk to you guys ... so what do you think ? Also, who is the best guy in the Bay Area (prefer SF) to have work on this car in general ? Thanks.
No clue what the baseline was or draw is now but assume normal draw at this point ..... only time will tell to see if that really fixed it ... but he was confident that this was the culprit fuse ... guess I was hoping someone would be aware of a known issue with this component
My car etc is in the other garage so may be off base but...this fuse is for the interior lights next to each door right? Are they switched off, always on or on only when door opens? Could be a simple as a dome light being left on. Alex was right you need to know the draw and also the time that elasped for the new battery to die to better determine where to look.
If I was in the Bay Area I would head to RMG in Sunnyvale or FD Motorsports in Brentwood.
No wonder there was a draw , there should be a draw.
You will notice that the battery will die even if fuse 29 is out.
As for the draw, a little more info would be helpful...
When driving, all is well electrically ? No dimming driving lights on stops ?
There is a famous culprit which is the rear auxiliary blower temp sensor.
When it is dead, it does not stop the rear fan from cooling the engine after 20 or so seconds, after parking the car.
So after a drive, stand close to engine and listen to see if the fan shuts off after a while.
Other culprits could be a worn alternator brushes and aftermarket radio
regards
