993 Forum 1995-1998
No dash lights
Old 08-31-2012, 01:47 PM
Ed Hughes
Ed Hughes's Avatar
I respectfully disagree that his symptoms sound like a relay issue.
Originally Posted by Chuck W.
You may have a problem with Relay Number 24, Part No. 964 618 103 00. Read the below thread I started in March of 2011.
https://rennlist.com/forums/993-foru...ut-solved.html
Here is the thread I found that helped me solve the problem;
https://rennlist.com/forums/993-foru...his-relay.html
Old 08-31-2012, 01:50 PM
Chuck W.
Chuck W.'s Avatar
And, you may be right. Or, .....
Old 08-31-2012, 02:18 PM
IXLR8
IXLR8's Avatar
Originally Posted by usnlynx
Alex,
I'll take a look this afternoon.
Do you know where the "Control Unit Instrument Light" is located? Something easy to get at?
Thanks,
Mike
Mike, if you go to Sheet 15 - Construction Components and look up Control Unit Instrument Light, it shows coordinates 7bQ for a LHD vehicle. You then look those up on the vehicle outline coordinates on the same sheet. In this case near the driver's side mirror and gas cap areas.
Relay 24 as mentioned above is the "Control Unit Instrument Light" module. It isn't shown as a "relay" on Sheet 1 - Lights.
Don't replace anything till you diagnose the problem.
Old 08-31-2012, 03:21 PM
Ed Hughes
Ed Hughes's Avatar
I was going on the fact that the lights were intermittent, then quit. An energized relay, that is allegedly sticking, doesn't drop in and out. He then found a burnt fuse, which allowed them to come on. Now, there is a suspect dimmer, which doesn't work-a relay either energizes and conducts power, or it doesn't. A bad relay will not keep the dimmer from dimming. The dimmer seems like it is a possible culprit, or another related connection.
But, electrical gremlins ain't fun...so, it is hard to diagnose over the interwebs.
Old 08-31-2012, 09:20 PM
usnlynx
usnlynx's Avatar
Ok...did some checking.
Fuse 36...good
R24 (license plate and instrument lights)...in place.
Ignition on, lights switch on. Gauges light up, but no dimmer control.
Fuse 36...taken out, lights off. Back in, lights on.
R24...taken out, lights off. Back in, lights on...still no dimmer control.
Looked at R12 (bridge)...don't have that relay.
Attached is a photo of my fuse and relay panel for reference.
Oh, also looked at fuse 18, but that only seems to affect gauge functionality only. No affect on the lights.
Just got a call from Porsche San Diego, new R24 relay is here. Will get it tomorrow and try it out.
Ok, will have to upload that photo later, can't seem to do it from my IPad.
Mike
Old 08-31-2012, 09:26 PM
usnlynx
usnlynx's Avatar
Just read the rest of the post. Will look into the Construction Componants diagram and see what I can find. Will not replay relay until more trouble shooting is done.
Cheers,
Mike
Old 08-31-2012, 10:06 PM
IXLR8
IXLR8's Avatar
Mike
Mike, it might be a good idea if you posted the model year of your 993.
This is the fuse and relay panel in my late 1995; no R24, but I have the R12 (bridge).
EDITED TO ADD: well there you go. Thats why it is important to list specifics. I just dragged out Vol VII of the Porsche Workshop Manual - Electrics, Wiring Diagrams and from 1996-on, R24 is in the fuse panel, which is why its not on my fuse panel. And re my PM to you, there are 4 sets of wiring diagrams: 95 (early 1995), 95/2 (late 1995), 96 and 97-98. BTW, the 96 and 97-98 schematics show a R12...go figure!
Old 09-01-2012, 12:35 PM
usnlynx
usnlynx's Avatar
Alex,
I have a 97 993 Cab.
Classic red and tan w/black top.
I will post pictures of my fuse/relay box later. Wife is using the computer (homework) and I can't find a way to post pictures fom my IPad (maybe there's a Rennlist app for that...lol)
Going to Porsche San Diego to pick up new relay. Hopefully I won't need it, and will be able to return it. If not, maybe someone else will need it...
Will be back in a little bit.
Cheers
Mike
Old 09-01-2012, 12:45 PM
Chuck W.
Chuck W.'s Avatar
Ed may be right. My only experience is with my problem and fix. But I am hoping that swapping out the relay will fix your problem. It would be an easy fix!
Old 09-01-2012, 07:11 PM
IXLR8
IXLR8's Avatar
Alex,
Going to Porsche San Diego to pick up new relay. Hopefully I won't need it.
Cheers
Mike
Mike, with it looking like a solid state device I'm wondering how "bumps" can affect it other than maybe a bad solder joint on the circuit board.
Can you pop the cover off your old one and post pics. If the cover has a circuit printed on it, I'd like to see a pic of that as well. It doesn't even appear to be a "relay"; what would it be switching?
Old 09-01-2012, 11:10 PM
usnlynx
usnlynx's Avatar
Default new photos
As promised here are the new photos.
1) is the cover from fuse box listing all the fuses and relays.
2) is a shot of the fuse panel. The "relay" in question is R24 located on the bottom row 3rd from right (its the black one with nothing on it; i.e. diagram or "1" sticker.
3) The "relay" in question.
4) The new "relay" (still in the box). The lable says "brightness control"...curious, maybe this isn't a traditional relay in the sence of "on/off"? It is the biggest one on the panel.
I don't know...
Cheers,
Mike
97 993 Cab
Old 09-01-2012, 11:22 PM
usnlynx
usnlynx's Avatar
Alex,
I agree with you. Hence the reason I was thinking maybe a loose connector on the wiring harness...maybe in the dash behind the gauges. Thats really the only thing that make sense. Or, as I am wondering, is that relay, not really a relay as we are thinking, but actually a controller and its just mounted in fuse panel. Like maybe some kind of rheostat controled relay...?
As far as fuse 36 blowing that could be that I simply missed it, or my rooting around and wiggling wires "touched" the short with caused it to blow...?
Maybe my problem will be fixed by the new "relay", maybe not. Maybe the problem resides with the dimmer control's rheostat... Maybe the ash tray light has is playing a role. Previous owner had a Kenwood stereo installed (with amp under passenger seat) and an IPod cord routed through the ash tray (I like that actually, just plug the IPod in and stick it in the ash tray compartment).
About the old relay, are you saying I should try to pop the cover off, as in open it? Or were you meaning just to find a diagram on it. There is no diagram on the outside like many of the others, just what is in the photo.
Cheers,
Mike
97 993 Cab
Old 09-01-2012, 11:28 PM
Ed Hughes
Ed Hughes's Avatar
Could be something more than a standard relay...as evidenced by the price?
Old 09-01-2012, 11:29 PM
usnlynx
usnlynx's Avatar
I will admit I was a little surprised at the $114 price tag for a "relay". Luckily, however, if I don't install it, I can return it for a "restocking" fee...lol
Old 09-02-2012, 12:18 AM
Chuck W.
Chuck W.'s Avatar
You could always meet up with a Rennlist brethren in your area and borrow theirs to see if that is the problem. Quick plug and play and you'll know.
Quick Reply: No dash lights
