993 Forum 1995-1998
Air conditioning died
Old 08-06-2012, 03:39 PM
ehanauer
ehanauer's Avatar
Default Air conditioning died
Today the air conditioner stopped working on my 993. All it does is blow ambient air. Up until now (including yesterday) it was working fine.
Any suggestions?
Old 08-06-2012, 03:52 PM
Van1
Van1's Avatar
Is your compressor kicking in when you turn your AC on?
Old 08-06-2012, 04:03 PM
ToreB
ToreB's Avatar
Most probably a leak in the A/C system, and the low pressure switch has stopped the compressor from running. Common issue...
Details here: www.porschehvac.bergvill.com
Cheers,
Tore
Old 08-06-2012, 07:13 PM
IXLR8
IXLR8's Avatar
Originally Posted by ehanauer
Any suggestions?
Yes, check that the single lead from the magnetic clutch on the A/C compressor hasn't disconnected itself from the connection within the passenger side electrical panel. Give it a light tug to verify.
Next, check the A/C relay under the driver's side electrical panel.
Both panels are in the engine compartment in plain view.
Old 08-07-2012, 05:23 PM
ehanauer
ehanauer's Avatar
Recharged, with dye. No obvious leaks. It worked great for about 5 minutes, then started blowing hot air. I turned around and drove back to the repair shop. On the way there, it started blowing cold again. Has been OK since.
Has anybody else experienced this?
Old 08-07-2012, 05:25 PM
ToreB
ToreB's Avatar
One or more of air flow control servos are probably beginning to give up the ghost. This is next on the checklist after a recharge. Have a look on the page I linked in my previous post.
Cheers,
Tore
Old 08-07-2012, 05:28 PM
P-daddy
P-daddy's Avatar
No leaks noted? My bet is with what Alex said above. Check all your connections.
Old 08-07-2012, 06:44 PM
IXLR8
IXLR8's Avatar
Eric, I don't know what your diagnostic skills are, but would you be able to check the A/C relay to see if a signal is getting to it to activate it? If it is working, then I'd check the wire to the A/C magnetic clutch. If the relay is not switching, then you have a problem downstream....low pressure as Tore already mentioned...and that would mean a freon leak as verified by a set of gauges.
It could be other things as well, but these are the fast 'n easy things to check....ten minutes if that.
Old 08-07-2012, 08:43 PM
GARY 95 993
GARY 95 993's Avatar
My guess is that it is the evaperator, the same thing happened to me.
Old 08-07-2012, 09:19 PM
IXLR8
IXLR8's Avatar
An RLer posted a DIY along with the link to Griffiths for A/C parts.
An involved job if it is the evaporator.
I wonder if the tech removed the driver's front fender liner and checked all the A/C related parts there. He can always use a freon sniffer.
Old 08-13-2012, 09:50 PM
griffiths
griffiths's Avatar
Recharged, with dye. No obvious leaks. It worked great for about 5 minutes, then started blowing hot air. I turned around and drove back to the repair shop. On the way there, it started blowing cold again. Has been OK since. Has anybody else experienced this?
If you have a good relationship with that repair shop just ask them if they can toss a set of gauges and check the pressures, and tell them what happened, sometimes a good shop will toss you a bone if your a good client.
Old 08-14-2012, 02:04 AM
NP993
NP993's Avatar
Make sure the fan on the condensor (I think it's the condenser) in the left front wheel well is not obstructed and is turning on properly.
Old 08-14-2012, 11:17 AM
ehanauer
ehanauer's Avatar
We've had a heat wave since the AC was recharged and it has worked perfectly since that first glitch. So if it ain't broke.....
Quick Reply: Air conditioning died
