Hole in Air Duct
Hole in Air Duct
OK, Getting ready to do some maintenance and just noticed a rather large hole in my air duct (part # 993 106 403 00). Part runs around $55 out of Atlanta. Do I need to worry about it? Should I slap some black duct tape over the hole or spend some more money and replace it?
Photo below. Thanks, Brian
This is cheap. Fix it. The fan blows air in over the engine and this hole is allowing some of that forced air for cooling to escape. No its not a "omg I'm going to destroy my engine-rush" to fix it, but don't skip it. Desert area or track use would add to the urgency to fix it.
Don't bother duct taping....I'm guessing the engine heat will make a mess of the tape and it probably won't hold the air pressure generated by the fan.
I'll step thru it so its clearer:
1. The 993 has an air cooled motor.
2. Static air isn't as good as moving air for cooling.
3. The big belt-driven fan in the back sucks air in, pushes it across the engine and out the bottom of the engine.
4. The "tube/vent thingie" is right behind said fan and part of the shrouding that directs the air onto the engine.
5. Ever notice the reasonably tight tolerence of the fan to the metal fan housing? This allows the fan to build air pressure and force air out the bottom.
6. A hole negates the effects in #s 4 & 5.
Yes, "tube/vent thingie" connects to the blower motor. Which forces air in when the engine fan isn't doing that (after you turn the car off), so yes it does have an "effect on engine cooling" in several ways.
Perhaps you should spend some time working on your car and less on the Internet.
Less "I think" and more "I am sure" please. "I couldn't tell a difference"....You did experiments and kept track of data, to reach this conclusion, right?
1. Since you like to talk about experiments and data, where is yours? Since you are "sure", this should be easy for you to present.
2. How many psi of air pressure is under the shroud (you tested this right?)
3. I drove cross country (3,100 miles) with a big *** chunk missing from the duct. Given the massive importance of this piece, I'm amazed I made it.
Look here chief, I do plenty of work on my car as many members can personally attest, while I don't recommend that you leave this gaping hole for very long, I'll argue that it has only a minor effect on engine cooling.
Perhaps i'm wrong...I'll just wait for your data to corroborate that.
It's a simple 10-15 minute job. Open two or three bolts, you see a couple of them on the photo above, and snap on the duct on the fan housing. As far as I remember, one of the bolts is a bit tricky to get to, but not a big problem. The biggest challenge in this job is not to drop any of the bolts into the air duct opening.
Cheers,
Tore
Cheers,
Tore
ok...so in the interest of providing another data point...I will post my fan shroud data. Like everyone else, mine has a hole in the same spot. I gotta tell ya though...when I first looked at it, I was extremely concerned. At least to me...it wasn't clear that the entire shroud wasn't a single large piece that went way down itn the bowels of the engine. Imagine my delight when I saw on here that the part with the hole in it, is a small, easy replaceable piece
Anyway...I took the shroud off of my '97, varioram, 11/96 build, car, and here is the part number: 993 106 403 00
Also, someone had asked about why this hole appears. I really think it's simply time and heat. Mine was really kinda brittle around the area where the hole was.
I'm off now to order a new one from Sunset...
Funny the timing of these posts, mine just cracked at the seam last week. I was wondering the same things as posted here. I guess I'll be ordering from Sunset too.
