DIY - Sealing The 993 Windshield and Rear Window
Hey Guys,
A few months ago I did the front and rear window sealing procedure on my car and took several photos documenting the task. I finally wrote up my notes and decided to post them in case someone else might want to try to do this procedure.
Just a couple of side notes. I bought my car in April 2011 with 43k miles on the odometer. I believe it has been located in Arizona and California it's entire life and was well cared for. I live in the Valley in L.A. so corrosion from the weather elements is not too big of a concern. Nevertheless, after reading about some of the nasty experiences some have had with corrosion around the window cowls, I decided to take the precautionary step of sealing the window gaps. I hope this will answer most questions about how to seal the gap, but if you have issues with corrosion, I will have to defer to others more experienced in that area.
-bruce
Concern
To prevent corrosion damage in the areas of the 993 front or rear window cowls, the gap between the glass edge and the car body should be sealed with an elastic polyurethane adhesive and sealant.
Tools and Materials
Wurth Bond+Seal, Wurth PN 890-100-2, grey, 300ml cartridge
(1 cartridge will seal 1 window, order direct from Wurth in USA 800-987-8487)
Front window outer seal, Porsche PN 993-541-925-00
Rear window outer seal, Porsche PN 993-545-225-02
Caulking gun
Painters tape
De-greaser
Q-tips
10mm socket wrench
Putty knife
Compressed air
Adhesive remover
Packaging tape
Nitrile gloves
See Also
Porsche 993 Service Manual
Porsche TSB 5106 9501 "Repairing Paint Damage Around Front & Rear Windows"
Introduction
On the 993 there is a large gap between the front and rear glass edges and the body which can collect and hold water. This can eventually lead to corrosion and costly body and paint repair. This article will illustrate how to seal the gap and prevent water from collecting underneath the outer seal and eliminate the risk of corrosion forming. Sealing the gap is a factory-recommended procedure.
NOTE: Repairing corrosion is outside the scope of this article. However, any corrosion found in the gap must first be corrected before proceeding with sealing the gap.
Photos and illustrations accompanying this article can be found at:
https://picasaweb.google.com/bruce.c...Y993WindowSeal.
See Figure 1 for a diagram of what the gap between the glass edge and the body looks like.
1. Remove 3rd brake light
Pull off cover and set aside. Remove 10mm nuts attaching light bar.
Set light bar on roof taking care not to scratch the paintwork.
See Figures 2-5.
2. Remove outer seal
Note aligning mark at top center. Loosen & remove the rubber seal.
See Figure 6.
3. Clean gap between window and body
Clean out the gap with Q-tips and a de-greaser. Then rinse out the gap with Q-tips and water.
See Figures 7-8.
4. Dry gap between window and body
Dry the gap all around the window using compressed air.
See Figure 9.
5. Mask off window and body
Apply masking tape around the window and body gap. The tape must cover the channel for the rubber seal on the window and the body must be covered where the rubber seal makes contact.
See Figures 10-12.
6. Apply sealing material
Puncture the cartridge seal and screw the application nozzle onto the cartridge. Insert the cartridge with nozzle into the caulking gun. Fill the gap between the window and the body completely with sealing material.
See Figures 13-17
7. Tool the sealing material
Wet a finger and drag it along the sealing material in the gap to create a smooth surface.
See Figure 18.
8. Remove masking tape
Remove masking tape from window and body.
See Figure 19-20.
9. Install new outer seal
Position aligning mark on outer seal at top center. Press the seal into the mounting channel.
See Figure 21.
10. Install 3rd brake light
Installation of the 3rd brake light is the reverse of removal.
Note 1
The rear window outer seal is extremely soft and easy to mark with fingernails or tools.
It is much softer than the windshield outer seal. Wear clean nitrile gloves during seal installation and press only with the finger tips. Do not stretch the seal during installation.
Note 2
Due to flex of the 993 body, you may find that a bottom corner of the rear window outer seal may pop up after entering or exiting a driveway. To solve this, secure the corner area with some of the sealing material. Tape the corner down for 24 hrs with packaging tape. When the sealant has cured, gently remove the tape and clean the area with adhesive remover.
See Figures 22-28.
The procedure to seal the gap between the windshield and the body is mostly the same as for the rear window with the following notes:
1. The windshield outer seal aligning mark is located at bottom center.
See Figure 29.
2. The outer seal is extremely hard to press into the mounting channel. It may be helpful to use the smooth
handle of a putty knife to help press the seal into the channel, taking care not to mark the rubber seal.
4. A putty knife blade can be used to help press the seal into the mounting channel. In a problem section, lift up
the seal slightly and use the knife edge to push the seal into the channel and then press down the seal to
smooth out any irregular areas.
5. The outer seal is the exact length required, do not stretch during installation.
See Figures 30-31.
There a couple of common sources of squeaks or creaks in the 993.
1. Front and Rear Outer Window Seals
A creaking sound may be heard when entering or exiting a driveway. As the body flexes the front and/or rear outer window seals may rub against the body and cause a squeak. This can be alleviated by lifting the seal and spraying all around the glass under the seal with 3M Silicone Lubricant (Dry Type) #08897 or a similar product. Periodic lubrication may be necessary. See Figure 32.
2. Door seals
In a similar situation, the rubber door seals around the top side of the window can squeak against the body when the car is moving. Spray these seals with the 3M Silicone Lubricant and eliminate the squeak. This spray can also be used to lubricate the window channel where the glass slides in the window frame. See Figure 33.
-bruce
by Bruce Carter
Rev 2-27-2012
by Bruce Carter
Rev 2-27-2012
Concern
Tools and Materials
Caulking gun
Painters tape
De-greaser
Q-tips
10mm socket wrench
Putty knife
Compressed air
Adhesive remover
Packaging tape
Nitrile gloves
See Also
Introduction
Procedure to Seal Gap Between Rear Window and Body
See Figures 2-5.
See Figure 6.
See Figures 7-8.
See Figure 9.
See Figures 10-12.
See Figures 13-17
See Figure 18.
See Figure 19-20.
See Figure 21.
Note 1
Note 2
See Figures 22-28.
Procedure to Seal Gap Between Windshield and Body
See Figure 29.
See Figures 30-31.
Some Tips for Stopping Squeaks
2. Door seals
Bruce, thank you for the great write up and photos
So with this sealant in place, I'm assuming no water can even sit at the bottom corners now?
I'm actually going thru the rear window rust repair now, wow the damage it can do is actually quite shocking.
Fantastic!
Anyone else done this?
I have bad rubber in the back window, and never drive in the rain because I get tired of removing it and blowing it out with compressed air everytime it get any water on it. Ive been thinking of doing something like this, and would like to make sure there are no long term downsides.
Thanks a lot for the write up.
button queen
Jesus--this absolutely rocks
This problem and fix has been threaded here before, though not with such detail and clear instructions and photos. I was spooked to try this before (fearing I'd slop the sealant on wrong or screw up the paint or some such other crime), but now even though I have a certified Garage Queen, I'm probably going to dive into this. I'm sure it applies to car washings too, not just rain on DDs.
Thanks.
Thanks.
Great job and write up!
Has been on my to-do list for a while. Having to park outside makes me now want to do it even sooner.
Thanks for spending the time to take pics and explain everything so well.
Thanks for the write-up. If you never have to replace the windshield again, I think you should be fine. However, getting it out for the next one will be much more difficult and the chance to cause damage (to the paint will be higher. It depends on the quality of the job and how they repair ANY damages caused by getting the old sealing out (this is described in the Porsche Manual, too). In practice, this is generally not being done because the problem can be hidden for years by the installer ... I always tell them: If you cause damage or see any existing issues, do not "cover up" and I PAY EXTRA to have it fixed properly. For due diligence, I asked them to give me a call to show me the frame, before the new windshield goes back in. It is a shame to do this but looking at all the issues, it is reality.
Seared
Installation is a bit more involved, but I'd be happy to give some pointers.
To the OP - excellent write-up!
Andreas
Hi
I squirted Tectyl ML under my window rubbers. The stuff is an anti corrosion penetrating fluid so I reasoned that it would sit where the water would sit. It cures to a waxy finish.
Berni
Berni
Its all in the Porsche 993 workshop manual that has been linked previously in pdf format.
EDIT:
Here is the link...It was originally provided by one of our rennlist members...I think "E_T" may be his screen name.
http://911uk.com/viewtopic.php?t=825...er=asc&start=0
Bruce7,
Thank you, thank you, thank you for a wonderful write up!
Basic Sponsor
Well done - nice work!
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
