Part number for footwell lamp (option XX2)
Anyone know the part number for the footwell lamp shown below next to the gas pedal?
It is the only lighting inside a Carrera RS (which has no ceiling lamps) and standard on Cabrio as well an option (code XX2) for other 993 cars.
I can't find it in PET.
Thanks to Dudley for the picture below.
Is there a way to control the footwell lights or is the operation fixed to the doors open/close?
The footwell option # XX2 had a USA dealership cost of $484.00 / $604.00 retail.
Pricey for what has to be generic VW lighting part..
When ordering the 993 the XX2 footwell lighting option made the long options list..... but in the end was eventually dropped from the actual order list. Oh well.
Is there a way to control the footwell lights or is the operation fixed to the doors oepn/close?
The center console has plastic break away sections to install the lamps. One can remove the console and break away the plug sections, cut the carpet (make an X and fold the points of carpet inward to glue) and then clip in the lamps.
The lamps are the same part number lamp that is under the front hood and over the engine 959.632.201.00 (or now 997.632.201.00).
The wiring harness would need to be cut into to wire the lamps up. The two lamps are wired in parallel.
This is an important detail ^^^ Contrast the wiring schematic of the coupe vs convertible and a retro fit should straight forward; by way of a step or two.
+1 THANKS, THANKS, and thanks again cupcar! This is one of those items i've had on my to do list, your explanation made me realize that with breakaways already in place this will be less of a hack job than I thought previously. Always thought footwell lighting was one of the best options to get.
It is interesting that the basic console is the same for all cars. There is a breakout for the airbag dash reinforcement used in cars so equipped and the lamp breakouts for those applications.
I filled in the airbag strut breakout and opened the lamp cutouts to create an RS style console after I removed my airbags. The supplies one needs to fill the airbag strut cutout is a piece of ABS plastic and ABS pipe cement from a hardware store.
The wiring diagram shows the two options: "INSIDE LIGHTS CONVERTIBLE" and "INSIDE LIGHT COUPE LEFT AND RIGHT".
The convertible option, which only has one lamp shown, has next to it the statement: : "FOR RS: 2 LAMPS PARALLEL".
So, I guess the convertible has one lamp somewhere else than the foot well and RS has two in foot well.
Good point.
The cabs, at least '95 cabs, have a single overhead light. It's located in the frame of the windshield between the two sunvisors. Horrible design that keeps falling out of its socket constantly, but that's another story.
Dave's car pictured above was a '96 IIRC and it has ignition key light which '95s didn't have either. '95s, however, has light in the key itself German engineering - design something completely non-functional, then design a solution to fix that while making sure original design remains in place. Repeat as nauseum
I've put LED into my key, it's a little better than the dim incandescent bulb.
There's also a write-up about installing the ignition light standard in '96+ cars into older '95s. Requires some drilling.
[QUOTE=Cupcar;10531095]It is interesting that the basic console is the same for all cars. There is a breakout for the airbag dash reinforcement used in cars so equipped and the lamp breakouts for those applications.
<snip>
Hello all!
I am curious to know if anyone has retrofitted their center console with footwell lights, and where the best place to tap into the car's wiring is. (I would be doing this on a coupe, meaning I already have the lights above the doorframes.) I would attempt to be as clear as possible with the wiring - i.e. not cuts if possible (if I could source extra OE electrical connectors). If cuts are necessary, I would use OEM-grade automotive electrical connectors (no scotch locks, etc.) ---- similar to the connectors I sourced in my bluetooth/cassette/CR-210/220 adaptation.
(Yes I know, such a frivolous detail. I like adding trivial factory options which my car did not come with --- like adding the rear fog lamps, adding hifi sound door panels, motor sound airbox, etc.)
<snip>
Hello all!
The interior lamps as well as the front trunk lamp are controlled by the alarm box under the passenger seat.
The only connectors where connection possible is at the alarm box itself at the Brown wire with White stripe (BR/WT wire in manual) going to pin 7 of connector #1 of the alarm box. If you have the tools you can remove the contact and install a new one with an additional wire to the new lamps in the console. Or, more easily simply tap into one of the wires.
The alarm box provides the "delay to off" function of the lamps.
The other connector for the interior lamps is under the carpet in the rear of the car on the right hand side and also has the wires to the sunroof in the same connector with all wires going into the right "C" pillar.
Another way one could do it is to run a wire from the BR/WT wire of the trunk lamp and fish it around the right hand side of cowl under the dash and to one of the central holes under the radio leading into the area above the console. This would be easy if the dash padding is removed, hard if not.
Thanks! This will keep me busy for a few weeks while I research the right connector/tool to remove the contact of pin 7 of connector 1 of the alarm box. :-)
