993 Forum 1995-1998
DIY - How to get interior fan working again /w heater bypass tube
Old 12-07-2011, 01:44 PM
axl911
axl911's Avatar
Default DIY - How to get interior fan working again /w heater bypass tube
All,
If you have the rs heater bypass installed or removed the heater blower, the interior fan won't run unless you have the temperature set to the blue dot.
Searching through RL, one of the solution was to connect 12V to the G1 & G19 of the ECU. There is a relatively easy way to do this. Just make a jumper to jump pin 30 to 87 on the heater blower relay (relay 5) in the engine compartment fuse & relay box.
Below is a pic of the jumper (circled in blue). I only jumped one of the pin, but the interior blower seemed to work just fine.
Old 12-07-2011, 01:55 PM
ToSi
ToSi's Avatar
neat, thanks. Would this faux relay (jumper) accomplish the same thing?
(pictures borrowed from Bill V's immobilizer bypass thread)
Old 12-07-2011, 02:07 PM
Texas993
Texas993's Avatar
Needed a little heat today, huh? Cold morning in DFW!
Old 12-07-2011, 09:31 PM
daltvater
daltvater's Avatar
Originally Posted by axl911
All,
You are my hero, I just did this and it worked like a charm! I was regretting doing that tube because the defrost went to crap. Now I'm back to normal, thanks a bunch!
Old 12-08-2011, 06:50 PM
shadow993
shadow993's Avatar
Great! +993
Old 04-21-2013, 08:22 PM
mr_bock
mr_bock's Avatar
Axl911,
Big Thanks for the blower delete fix!!!!!!!
Way better than the resister fix that I had been using.
Awesome!!!!
Rennlist, what a great place!!!!!!
Old 04-22-2013, 08:15 AM
ToSi
ToSi's Avatar
or, plug 964.610.184.00 in place of the original relay (& remove 30a fuse to disable power to the heater fan leads). Like this:
Old 04-22-2013, 10:43 AM
Triple G
Triple G's Avatar
Would this be the procedure to use on my 1996 C4S?
TIA
Old 04-11-2014, 05:12 PM
71-3.0-911's Avatar
Just did this on my 96 C2 and worked like a charm.
Old 04-11-2014, 08:08 PM
jhg41977
jhg41977's Avatar
I just installed the rs tube, have not yet turned the car on. Is there a relay I need to remove since I am not running the blower anymore?
Old 04-11-2014, 09:45 PM
Eurotrio
Eurotrio's Avatar
Mine worked just fine even wit the fan set to low speed
Old 04-11-2014, 10:58 PM
71-3.0-911's Avatar
On the fuse box diagram, remove the relay labeled number 5 and put the jumper from pin 30 to pin 87. It's the horizontal middle slot on the right to the vertical middle slot on the left. Easy day. Make sure to pull the 30a fuse so the connector for the blower isn't hot.
Old 06-05-2014, 06:02 PM
lopro
lopro's Avatar
this worked great, thanks for the info. I aswell installed the correct jumper relay pn 964.610.184.00 and pulled the fuse #11 (30amp) now its time to install the 993.211.941.00 bypass tube with 964.106.403.02 fan duct, Go figure most 95 also have the updated 96-98 fan duct pn 993.106.403.00
Old 08-28-2014, 09:53 PM
David A
David A's Avatar
I just did all this and got all the parts from Sunset Porsche. Worked great! Thanks
Old 02-03-2015, 05:03 PM
FlyingDutchman
FlyingDutchman's Avatar
what did you guys do with the vacuum line that connected to the heater blower? Can I just cap it?
Quick Reply: DIY - How to get interior fan working again /w heater bypass tube
