That new clutch smell
I just installed the lightweight flywheel and new clutch, along with new clutch master, slave and slave hose. The clutch pedal feel is very smooth and easy. The clutch engages close to the floor and it seems to be either in or out. It is diffiuclt to control, and I have stalled the car a few times, or rev it up too high. When I smoothly engage the clutch I get a slight burnt clutch smell in the car.
Does the clutch disc need to get conditioned or something? Is it going to get easier to engage smoothly and lose that burning smell? Is this within the range of normal experience for new clutches?
Ha! Me too! I thought I was going to burn up the clutch in a 1000 miles. I’d rev it up to get rolling and the clutch would STINK. My car would stall if I pushed in the clutch on decel. It's very embarrassing to stall the car in the front of a line of cars when the light changes. I can just imagine the people behind me laughing about the guy who can't drive his Porsche.
I had to have some other ECU work done so Steve Weiner took care of the stalling issue too. And I have learned to drive with the lwf. It took some time to get the clutch disengage and the throttle synced together from a stop and on shifts. I haven’t smelled that awful clutch stink since.
I had a heavy duty "race" clutch with LWF and had a terrible time with starting out at first. Heavy pedal, little modulation, very grabby. Good news is after a while it becomes much easier. Cheers.
Anyway, I could imagine that the clutch isn't totally unlike brake pads, where there's a break in period, transfer layer, etc etc. Since you have a lot less inertia to use, you have to substitute revs and slipping, and that's going to mean heat and likely the stink while everything's getting broken in. I'd only worry if it doesn't stop, but sounds like this is pretty normal going by the other posts.
Travis,
Once it mellows out we can get together and you check it out. I also installed the RS motor mounts. Dropping the engine is quite an adventure that I recomend to anyone wanting to get to know their car better. It is a little intimidating before you start, but once in the middle of it, things feel much more comfortable. It makes a lot of sense to do the 90k service at the same time. I did a lot of delayed maintenance that would have been extremely difficult to do with the engine in. Plan on spending the extra money to do these things. I'll PM you with a list of all the stuff I did while the engine was out. I'll try to put some prices, but I really don't want to know how much I spent.
My new clutch and flywheel smelled a bit at first, but, it went away after a few hundred miles. I beleive that if that short hose that vents the tranni to the intake is not intack, then the smell may last a little longer. Of course, if the airbox is drilled for the motorsound reason, then there wil not be enough vaccum for the tranni to vent to be effectively. Then again, maybe the tranni vent may not make that much difference?
There is much written on rennlist and elsewhere re pros and cons of LWF. Personally, I like it. There is no doubt the car is more responsive. I have learned to avoid the occasional stalling ( I have a SW chip).
I have had no problems with the LWF. No stalling issues what so ever. I haven't had a chance to drive it aggressively yet, so I can't comment on the performance aspects. I have a 96.
