993 Forum 1995-1998
Dropped the engine over the weekend w/pics
Old 03-14-2011, 06:25 PM
flatsixforme
flatsixforme's Avatar
Default Dropped the engine over the weekend w/pics
There have been a few engines dropping this winter here on rennlist so I thought I'd join the fun. Being a first timer I made sure I went slow and double checked things often. After two long days and the helping hands of some friends (kjr914 and a another friend John) we were able to roll the lump out at about 5 last night. What a great feeling!
Some notes off the top of my head:
- Throttle cable...really easy to disconnect it at the pedal and pull it through the tunnel of the transmission.
- Draining the power steering pump/resevoir...manual says to let it drain below but we found if you cut a plastic water bottle in half you can stuff it down in the perfect place to catch all the fluid. We didn't spill a drop!
- Fuel lines...one of the more interesting sections as the fuel line bolt was not going anywhere and with such narrow threads on the rail to give counter pressure you really do risk breaking something. Since a torch was out of the question I tried some Kroil but that still didn't work so I plugged in my wood burning iron with flat tip on the nut for several minutes in a couple different places...whola!
- The driver side eccentric bolt was a challenge as it hits the heat exchanger...the solution is to lift the engine up a couple inches
- Make sure you have a good assortment of rubber stoppers and vaccum line caps...I had a bunch and still could have used more.
- The engine mounts can be a 10 minute job or a 30 minute job if they are so old that the rubber housing breaks free and startes spinning freely (I have a C4S mount so not all are the same)...the fluid reaks like 100 year old fish guts by the way! You guessed it...mine took 30 minutes and two people. It was hard to get a good hold on the square metal piece on top of the bolt to hold the botl from spinning...especially on the driver side.
- Don't forget the clutch slave line...we missed that in the process and noticed as we were lowering.
Now the real work begins....
Here are some pictures of the fun!
The untouched engine
The engine block craddle block of wood...took this idea from someone on here and it worked great...and was a great excuse to use the air hammer!
The power steering drain cup
Everything all labeled
Keith figuring out how to shim the transmission jack
Starting to come down!
The picture I've always wanted to take
This might be some sort of record...3 grown men stuffed into a 993 engine bay?!?!?
The following 2 users liked this post by flatsixforme:
NickDLT (01-30-2021), Vipergonza (06-16-2020)
Old 03-14-2011, 06:31 PM
No HTwo O
No HTwo O's Avatar
^That's very funny!
Old 03-14-2011, 06:32 PM
Paul902
Paul902's Avatar
Nice work!
Old 03-14-2011, 06:35 PM
CalvinC4S
CalvinC4S's Avatar
Great job! First timer doing a 4S, those 2wd guys have it easy.
Old 03-14-2011, 08:12 PM
porscheralph
porscheralph's Avatar
Nice photo's - now that it out - what are you going to do with it???
Old 03-14-2011, 08:33 PM
Slow Guy
Slow Guy's Avatar
Beautiful car, love the color!
Oh, and good job.
Old 03-14-2011, 08:37 PM
Vorsicht
Vorsicht's Avatar
Congratulations! Nice job and so clean! Love that color...
Old 03-14-2011, 08:50 PM
AOW162435
Seared
AOW162435's Avatar
Adam,
Nice work! That last pic is priceless.
Andreas
Old 03-14-2011, 08:57 PM
Stealth 993
Stealth 993's Avatar
Why did you drop the engine in the first place?
Old 03-14-2011, 09:08 PM
flatsixforme
Thanks guys! I got a kick out of that last picture too, glad we went through the effort to do it.
I dropped the engine to do a LWF and new clutch primarily as my current one is almost gone. Also, I'm going to do an AWDectomy since it is very easy to get the torque tube out with engine gone. I do a lot of time trials so the 100 lbs will make a difference for me. And, of course all the while I'm in there stuff like, plugs, wires, dist rebuild, caps, rotors, valve cover gaskets, chain tensioner gaskets, PS belt, new clutch slave, new clutch slave rubber line, lifters, fuel filter, SAI port clean, RMS, Wevo engine mounts, rennline rear subframe solid mounts, rennline gusset kit for engine carrier...I think that gets most of it but I'm sure I'm missing stuff. Bottom line, I'll be a busy guy for the next couple weeks!!!
Old 03-14-2011, 10:17 PM
simpsoap
simpsoap's Avatar
Nice! Looks like you have your work cut out for you...More pics
Andy
Old 03-14-2011, 10:35 PM
axl911
axl911's Avatar
It's a great feeling when you wheel that engine/tranny off and out of the car isn't it?
Old 03-14-2011, 11:23 PM
cabrio993
cabrio993's Avatar
Truly inspirational. Posts like these makes me stop complaining about my 2 hour oil changes. Keep it up!
Old 03-15-2011, 12:23 AM
cosmic_993
cosmic_993's Avatar
how many miles on your car? not doing top end?
Old 03-15-2011, 12:38 AM
Paddy
Paddy's Avatar
Looks like fun!
Quick Reply: Dropped the engine over the weekend w/pics
