993 Forum 1995-1998
Where to buy a single Bilstein PSS10 drop link?
Old 01-17-2011, 09:47 AM
MrBonus
MrBonus's Avatar
Default Where to buy a single Bilstein PSS10 drop link?
Yes, I've read through the volumes of broken drop link discussions on this forum. I imagine this is an installation issue as it broke on the way home from the shop (PSS10s/M030 sway bars).
Where do I order a fresh driver's side drop link?
Old 01-17-2011, 09:50 AM
ABCar
ABCar's Avatar
Call Darin at FD?
Old 01-17-2011, 10:26 AM
MrBonus
MrBonus's Avatar
Originally Posted by ABCar
Call Darin at FD?
Thanks.
Also, does anyone know if that third locking collar is supposed to go underneath the drop link collar?
I've read numerous tales on here of the link collar coming loose and causing similar havoc. I just want to have this done right the second time.
Old 01-17-2011, 12:47 PM
Paddy
Paddy's Avatar
What's your ride height set at? You may want to consider RS drop links.
Old 01-17-2011, 12:48 PM
MrBonus
MrBonus's Avatar
Right around ROW ride height. My issue appears to be the collar getting loose and not clearance with the rear toe link.
Old 01-17-2011, 12:49 PM
Paddy
Paddy's Avatar
FWIW I use a lock collar on my setup:
Old 01-17-2011, 12:53 PM
MrBonus
MrBonus's Avatar
Yes, the locked collar certainly makes sense. I'm trying to debate frustration of reinstalling everything vs. definitive solution.
Old 01-17-2011, 12:58 PM
MrBonus
MrBonus's Avatar
P.S. Nice Motons!
Old 01-17-2011, 01:02 PM
Paddy
Paddy's Avatar
Ian, are you using the stock sway bar? I'm assuming you do track the car according to your avatar picture. If I were in your shoes I'd order two RS drop links and reposition the sway bar and install two more collars and be done with it.
If not, I'm pretty sure I have a stock drop link in my garage- you pay shipping it's yours.
Old 01-17-2011, 01:06 PM
trophy
trophy's Avatar
That looks like an installation error, it appears the locking collar was not tight enough causing the swaybar link bracket to rotate.
I had only one collar on my PSS9 setup without issues, you just need to get them tight and they will stay in the right position. My car ran a number of years on the track without issue.
Old 01-17-2011, 01:07 PM
MrBonus
MrBonus's Avatar
I have M030 sway bars, front and rear. I'm probably going to do exactly what you just recommended.
Yes, I do track the car. I'm assuming you've had no issues with your RS links?
Old 01-17-2011, 01:08 PM
MrBonus
MrBonus's Avatar
I prefer this solution. It's more time and cost effective.
Old 01-17-2011, 01:12 PM
Paddy
Paddy's Avatar
https://rennlist.com/forums/showthre...ferrerid=24812
No problems since then.
Old 01-17-2011, 01:18 PM
MrBonus
MrBonus's Avatar
Thanks for your input. I remember reading your thread ages ago now that I think of it.
Old 01-17-2011, 01:22 PM
Paddy
Paddy's Avatar
No problem. Good luck and hope to see you track side this year!
Quick Reply: Where to buy a single Bilstein PSS10 drop link?
