993 Forum 1995-1998
Brake bias issues
Old 11-26-2010, 08:45 PM
aribop
aribop's Avatar
Question Brake bias issues
I updated my brakes to turbo brakes all the way around and am wanting some input on the best way to increase bias to the rear.
I ask because during heavy breaking I will lock up the front wheels momentarily before the ABS kicks in. So I figure I can move some of the bias to the rear to have a more balanced braking experience.
At this point I'm thinking that hopefully I can swap out the proportioning valves on the rear brake lines to allow more pressure to the back.
All comments and suggestions welcomed. Thanks, Albert.
Old 11-26-2010, 10:01 PM
trophy
trophy's Avatar
One option is to put a more aggressive pad in the rear. I know of guys that use Pagid Yellows in the front (RS19 or 29) and then use a Pagid Black in the rear (RS14)
Old 11-26-2010, 11:51 PM
NC TRACKRAT
NC TRACKRAT's Avatar
I'm going to think "out loud" here...If you increased your brakes on all four corners, the system should be as balanced as it was before. Keep in mind that your fronts should always bear the heavier load than the rears. Before swapping proportioning valves, be sure your ABS is functioning properly.
Old 11-27-2010, 12:05 AM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Steve offers a good suggestion, depending on your driving skills.
The other good one is to install a pair of RS rear calipers,..this works VERY well, too.
Old 11-27-2010, 11:14 AM
Bill Verburg
Bill Verburg's Avatar
993tt brakes have far more front bias than regular 993, far more than any other 911/964/993/996/997 I've ever checked on.
as noted use a pad combination w/ moe rear such as Pagid yellow front black rear or install RS rear calipers.
RS rears are great but they do move bias way to the back, to take full advantage you will want a low, stiffly sprung car w/ effective lsd.
Old 11-27-2010, 03:55 PM
jscott82
jscott82's Avatar
From what I know there is no "proportioning valve" on a 993, the bias is built into the master cylinder. There are limiter (blowoff) valves that limit ultimate pressure in a panic stop, but from what I have read the pressure limit is plenty high and they do not need to be removed (unlike the 964).
Question though: Anyone know what happens in an ABS car if the rears lock up first? In a non-ABS car things can get hairy real quick… but how does our ABS handle it? Is it smart enough to recognized and correct for it or does the same danger still apply?
Old 11-27-2010, 04:43 PM
Bill Verburg
Every 993 has at least 1 p/v, some have 2. There is no bias in the m/c it is a straight 23.8mm f/r unit.
cars w/ awd and cars w/ M220 option(lsd& abd) have 2. These cars have 4 channel abs others have 3channel(1 for each front wheel & 1 for the rear axle)
the p/v(s) is on the back of the abs pump. the 4 channel cars will have 2 p/v's(1 for each rear wheel) and 4 separate lines, others will have 1 p/v on the single rear circuit.
Old 11-27-2010, 05:06 PM
jscott82
jscott82's Avatar
Agree with everything you stated... except I believe they are blow off valves rather than proportioning valves... Here is the answer I recieved from Joel Reiser when I ask him several years ago...
Thanks for great questions. If we gave out coffee mugs for great ones, you would get one for this. I've been wondering when someone would ask this. The brake pressure regulator is different from a bias valve. This is a common confusion. What Porsche has done here is put in a valve that does nothing, unless and until the pressure (to the rear brakes) reaches some defined large value. At that point it will cut off any further pressure. So it does not set the bias for normal braking, it sets the bias for a panic stop. Normal braking includes light, medium and heavy, while the pressure limiter (or regulator) only kicks in at the max. The rear pressure regulator in the 964 cars was too limiting for track use when the front brakes were upgraded. So what Porsche did in the Carrera Cup cars was to remove and bypass it, with a plain pipe (a longer one to skip over the distance previously spanned by the regulator). This was part of a set of changes which included bigger black front calipers, rotors, and pads. Since more braking capacity was added up front, the idea was to try to add a little more at the limit by removing the rear limiter valve. A lot of people like to change them in the 964 to use a different one, such as the C2 Turbo one, that is a better solution for a driver ed and street use car than just discarding it, as you would for a trailered race car on slicks. The pressure regulators in the 993 are OK. I would not mess with that. Actually I had a 1995, and did the big red brake upgrade, and didn't mess with the regulators, and the car and the brakes were great. I also used Pagid orange. They can squeal and throw a lot of rustwater up in big rainstorms, but on the track they are outstanding. And normally on the street they are tolerable, apart from that. Though it is always a good idea to check your rearview mirror before braking hard, since you can stop a lot faster than they can. I say "regulators" in the 993 versus "regulator" in the 964 because there was one in the 964 for the rear brakes, while there were two in most 993's. The first 993's had only one rear brake circuit, but all the turbos, and C4's, and cars with ABD had two rear brake circuits, therefore they had two regulators installed, one for the left rear line, and one in the right rear line. All of the regulators are installed at the ABS hydraulic unit in the trunk. They are a few inches long, a round cartridge sort of looking thing. Joel Reiser - PCA WebSite - 2/25/2005
Old 11-27-2010, 06:14 PM
ninjabones
ninjabones's Avatar
This will provide my segue into another related topic.... I've always wondered how to potentially improve the the ABS in a 993 without spending $10,000 on a Bosch M4 kit. With slicks, stiff suspension and various racing conditions, it sure would be nice to take advantage of a more performance oriented ABS program (or perhaps even different programs for different conditions). I don't think I've ever heard of anyone "chipping" or re-programming a stock Bosch ABS controller.
I guess if it was possible, someone would have done it... but then again, the obvious consequences of an error in this department would be quite dire, and maybe the liability associated with messing with the ABS has prevented any industrious soul from attempting to market it or make available a "motorsport tune" for our ABS controllers. I know some guys have installed 996 cup ABS units in their cars, but that too would be pretty pricey.
Old 11-27-2010, 06:31 PM
Bill Verburg
js, thats what all hyd p/v's do. Joel is just calling it a regulator instead of a p/v(short for proportioning valve) You can argue semantics all day, but in the end they cut a % of line pressure above a set point called the knee, for n/a 993 inc. RS the knee is at 40bar and above that the rear line pressure is reduced by 46%. They do serve in a panic stop because the line pressures in such a situation usually exceed the knee pressure, but they also work in plain old max braking such as at the end of a straight. It is correct that at pressures below the knee, f & r line pressures are equal and not affected by a p/v. adjustable p/v's generally just change the knee pressure and could theoretically be adjusted to a knee pressure of zero or whatever the residual line pressure is from an unapplied brake.
When max braking occurs weight is transfered to the front so you need less line pressure in the back, the pressure curves when a p/v is used can more closely correlate to the curve needed than an open rear line.
A 964RS has too much front bias due to differential rotor size and caliper piston sizing, they need to remove the p/v to get enough rear bias even though the rear pressure curves are less than ideal. Similarly early 911 have close to ideal native bias but can profit from fine tuning the shape of the rear line pressure curves, though most don't experiment in this area
a 993 has pretty good base bias but still profits from the p/v, a 993tt is way worse than a 964RS, and can similarly profit from removing it's 2 p/v's, a 993RS on the other hand has a lot of static or base rear bias, it approaches the max in this area and profits greatly from reducing front weight transfer under braking and stabilizing braking w/ an effective high lock up lsd.
the only devises in the m/c area that affect bias are the twin master setups that are used on RSR and late Cup cars. Here different sized m/c for the front and rear are used as well as a mechanical bias bar. Both of these mechanisms affect equally bias at all line pressure levels and are not proportionally effective at all. There are some front engine cars that are equipped w/ stepped m/c, these are functionally the same as a twin master setup w/ 2 different m/c
Some people do not like a p/v among the reasons are the time that it takes to engage and release line pressures, it takes a very finely trained foot to detect this response lag but some do take issue.
Old 11-27-2010, 06:35 PM
Bill Verburg
Geoffrey installed a 993RS brain in his, others are reportedly using 996Cup abs
Old 11-27-2010, 08:50 PM
aribop
aribop's Avatar
Originally Posted by Bill Verburg
...to take full advantage you will want a low, stiffly sprung car w/ effective lsd.
I just upgraded the stock suspension to PSS9 and will be going with RS sways shortly. The car is set to RS height and was corner balanced and aligned. The car felt really good at Road Atlanta a few weeks ago and it has factory LSD and ABD as well.
My car has two valves, one to each of the rear lines.
Does anyone want to buy a pair of almost new 993tt rear brake calipers so I can buy some RS calipers??
Does anyone here run EBC pads? My car is my dd and is performing more weekend duty at the track so I was trying to find a good balance of street/track pads. Is my thinking silly and I should have a set of pads I swap in for track use?
Thanks!
Old 11-28-2010, 01:10 PM
trophy
trophy's Avatar
Here are some links to Geoffreys work when he was building his 964 Racecar. talks about ABS, and the associated controllers and wiring.
https://rennlist.com/forums/964-foru...e-upgrade.html
https://rennlist.com/forums/964-foru...ke-system.html
Old 11-28-2010, 01:36 PM
TheOtherEric
TheOtherEric's Avatar
I also switched to Big Reds and have just lived with the slightly front-biasing of this setup. You can do the math, but IIRC it shifts the brake bias around 7% forward (roughly). Sure RS calipers would be better but is it worth the price? Perhaps, but not for me.
I actually bought new higher Pressure Limiting valves (for the TT) for like $80 each(?) from Porsche, but I'm not bothered enough to even install them. Maybe someday.
I might be seeing higher brake pad wear in the front now, but it's not too significant.
Old 11-29-2010, 12:02 PM
Bill Verburg
the tt setup shifts hyd bias from 1.572 in a n/a to 2.061, that's ~31%
compare a n/a to RS 1.572 to 1.472 is ~6.7% more rear in an RS, whicj is why youwant to limit forward weight transfer and use an effective lsd
compare a tt to RS 2.061 to 1.472, there is ~40% more front in a tt
the 993 n/a actually has a little more front bias due to the slightly larger front rotor compared to rear rotor diameter. the tt and RS have the same rotor diameter f/r so.
W/ any of these the big issue for track guys is rotor cracking, the best available solutions all involve non drilled 322mm rotors
Quick Reply: Brake bias issues
