Sumitomo tires
#61
I just completed a 4,000 km trip of which about 1,500 km was in rain of varying intensity, including some monsoon level conditions.
I was really pleased with how these tires grip in corners, and with how they get through standing water with only a bit of lift.
Most of the route was on winding roads in the Northwestern states.
#62
Sumitomo HTRZIIIs great in the wet, good in the dry
While they do very well on track and take forever to wear, these HTRZIIIs are still not really track tires though. My last rears were retired prematurely with half to one foot long internal sidewall bubbles after a dry spin during a sprint race. That's with running hot pressures close to the factory cold pressures. I also have some suspicions about their compatibility with PSM, at least on a hard-pressed 996 Turbo. Not sure why, but my PSM faults to off much quicker with the Sumis than with some other tires. Usually in the first few corners in the dry, sometimes after a few laps. In the wet, it usually takes at least a few laps to happen. I suspect my PSM is flaky to start with though as I haven't seen others complain of this, but I like my car better with it fully off anyway.
The Sumis were still good enough though that I bought another set for the road, but on dry tracks I'd now rather run r-comps like Nitto NT01s/Hankook Z221s/Dunlop D3Gs etc.
#64
I ran these before switching to Dunlip Star Specs. I really really liked the tires.
I got 10,000 miles out of my first set of rear tires and only 5,000 miles out of the 2nd set due to more track days. The fronts still had a little bit of life to them when I swapped the whole set out.
When my Jetta tires wear out I am going with Sumi's all around
