993 Forum 1995-1998
Airbag controller removal
Old 06-24-2016, 01:31 AM
  #31
Ponchobroke
Ponchobroke's Avatar
So this ends up being a great thread for those of who have decided to remove the entire airbag system for what ever reason.
But, though I understand the DME circuit and the warning light circuit.
I cannot identify which pins to jump in the harness plug to provide power yo the DME.
Can someone please describe which pins/sockets you jump on the harness plug? Basically which are sockets for pins 5 and 20?
I do understand the warning light tab goes in the 3rd double slot on the right.
Thx...
Old 06-24-2016, 10:23 AM
  #32
jscott82
jscott82's Avatar
Thx...
Looks like the pics from my original post got deleted.
here it is.
Old 06-24-2016, 12:51 PM
  #33
Ponchobroke
Thanks very much, now i can finish my project...
Momo wheel, airbags delete and lower dash delete.
Old 06-07-2019, 07:02 PM
  #34
trendo
trendo's Avatar
Did this today, works great. Thought I would add more pictures.
I used the chisel method to get it out (not fun), then removed the torx screws to get inside.
entire unit pulls out
Used a small side cutters to get the bottom pins cut from the back. The top pins were cut by running a small hacksaw blade across them.
Soldered the appropriate pins
Put it back in the original case for a clean install.
Then it went back in the car!
Did a quick test, all lights off, and car starts.
Old 03-23-2024, 04:03 PM
  #35
KASH '95 993
KASH '95 993's Avatar
My airbags suddenly blew after I dropped in a pot hole. Is this due to bad impact sensors in front bumper?
I have new bags but don't want to replace without fixing the issue that cause them to deploy in the first place.
Thanks in advance for any advice.
Quick Reply: Airbag controller removal
