993 Forum 1995-1998
key fob battery change
Old 11-04-2009, 03:50 PM
foonzoo
foonzoo's Avatar
Default key fob battery change
Hi,
As I only received one key fob when I bought the car, I would like to order one or two batteries in spare to play it safe.
Does someone know the exact model I should order ?
Thanks in advance !
Old 11-04-2009, 04:23 PM
NP993
NP993's Avatar
You can get them at any Rite-Aide/CVS/etc.
Old 11-04-2009, 04:41 PM
foonzoo
foonzoo's Avatar
Ohhh I know where to find them , I just need to know the reference of the battery.
Tx
Old 11-04-2009, 04:45 PM
Ocean Blue C2S
Ocean Blue C2S's Avatar
bought a new battery for the Key-fob at the local Porsche dealership, it was very expensive for this tiny battery, it you find a better source let people know!
cheers,
Bert
bert
Old 11-04-2009, 04:48 PM
SMehder
SMehder's Avatar
Location: Greensboro, NC & Highlands, NC (on the real roads)
I bought one at Radio Shack for about $2. Take the fob with you and they will find the correct battery.
Old 11-04-2009, 04:54 PM
dbf73
Boost Junkie
dbf73's Avatar
see this thread and keep a spare battery in the car along with the small Phillips head needed to replace it
V
V's Avatar
Is there anything in particular you need to think about when you change battery? I opened my keyfob with the small philips screwdriver and the whole electric board came out.. Is it supposed to be lose like that? then I replace the battery but no juice.. The small diode doesn't light up when pushing the button either..
Old 11-04-2009, 04:56 PM
cmat
cmat's Avatar
Battery is MN21 or A23. Mine was labeled 21/23. Available almost anywhere.
Old 11-04-2009, 05:42 PM
foonzoo
foonzoo's Avatar
Thanks, very much appreciated !
Old 11-04-2009, 05:43 PM
dbf73
Boost Junkie
dbf73's Avatar
IIRC, the board just sits in there. Just make sure you have the polarity right and that the new battery is good. reminds me, I should change mine
good luck
Old 11-05-2009, 09:23 AM
ballpeen
ballpeen's Avatar
Right, A23. Just picked up a couple last night myself ($1.99) and stashed them in the glove box.
Old 11-05-2009, 12:06 PM
foonzoo
foonzoo's Avatar
Yep, just did the same Also, the phillips that comes with the toolset works ok to open the key fob.
Old 02-19-2019, 09:20 PM
DLook
DLook's Avatar
$4 at Walmart
Old 02-20-2019, 11:05 AM
NC TRACKRAT
NC TRACKRAT's Avatar
Just in case of fob battery failure, I purchased a small plastic pill vial that's just big enough to put an A23 battery inside, then hung it to the fob.
Old 02-21-2019, 01:38 PM
drodg
drodg's Avatar
That is a great idea.
Quick Reply: key fob battery change
