993 Forum 1995-1998
Transmission Mount Replacement
Old 11-02-2009, 10:37 PM
chaoscreature
chaoscreature's Avatar
Default Transmission Mount Replacement
I have been searching Rennlist and Google for pictures or a good description of what it takes to swap out the transmission mounts. I am making motor mounts right now (I will post pics tomorrow) and may want to do the tranny mounts soon since I have heard that they also tend to fail.
Please point me in the right direction, or tell me how involved the swap is. My main reason for the new motor mounts is to hopefully improve the shift feel (plus I am pretty sure the stock mounts are dead, I can fit my finger between the rubber and the steel cup).
Thank You!!!
Old 11-02-2009, 11:03 PM
shu
shu's Avatar
Making motor mount?! wow.....
Old 11-02-2009, 11:53 PM
AOW162435
Seared
AOW162435's Avatar
It's tough to beat factory RS or WEVO mounts for sheer simplicity. What is your solution?
Andreas
Old 11-03-2009, 12:59 AM
Nollie
Nollie's Avatar
Thank You!!!
Here's a DIY where they remove the transmission for LWF / clutch install, that should give you a fair idea of what's involved. https://rennlist.com/forums/993-foru...p-and-lwf.html I just dropped my transmission but I brought the engine with it.
And the PET for the transmisison mount / carrier is here (you'd be looking at the bottom for RWD and the top for AWD)
Andreas
Those full metal ones that just sold up in Canada look pretty simple But I too am interested in the solution.
Old 11-04-2009, 10:51 AM
chaoscreature
Nollie,
Thank you for the diagram and the link. I had read that article earlier when I searched Rennlist. Unfortunately they went straight to disassembling everything and I want to find out if its possible to replace the transmission snout mount without tearing the whole car apart.
One of the techs at Black Forest said it might be possible to slip the mount out without removing the transmission. Has anyone done this? If not I will just leave it alone for now.
The engine mounts are being done due to budget issues, not because I think I can make something better than either the WEVO's or the Porsche RS mounts. I will post pics tonight after I pick up my Energy Suspension bushings for them.
Thanks again!
Old 11-04-2009, 02:02 PM
Archilla
Archilla's Avatar
From what I can tell in the photos from the DIY link, they never separated the carrier from the transmission, they just unbolted the carrier from the car and removed it with the trans. The real answer that is needed to determine whether the transmission mount can be replaced without removing the trans from the car is if the mount (23 in the diagram above) is a slip fit or if it is pressed into the transmission case. I've thought of replacing the mount as well, but have not done it yet because I'm not sure if it can be done in the car. Let me know if you figure this out.
-Ruben
Old 11-04-2009, 09:03 PM
Bill Verburg
Bill Verburg's Avatar
Thank You!!!
RS trans mount
normal is similar but softer
Old 11-05-2009, 01:20 AM
chaoscreature
So, if you drop the cross member, is there enough room to wiggle the mount out without dropping the rest of the engine/trans? It looks like there should be. If it seems plausible to do the trans mount swap in an afternoon then I will probably try that next weekend.
Here are the mounts that I made. They still need the polyurethane inserts, but they are pretty much done (I get them tomorrow). I am going to bake the mounts tomorrow to reharden the aluminum... then maybe paint?
Old 11-05-2009, 11:16 AM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Nice welds, looks machine welded!
Just make sure they sit flat and that any part of the weld doesnt hang it from sitting flat.
Old 11-05-2009, 02:11 PM
AOW162435
Seared
AOW162435's Avatar
Awesome! You, sir, have a very steady hand.
Somehow I thought the tranny mount is pressed into place?
Andreas
Old 11-06-2009, 11:55 PM
chaoscreature
Motor Mounts are done, painted and installed. They are just WEVO knockoffs. The old mounts were definitely shot. It was VERY easy to swap them out, probably only took 20 minutes. I am waiting for tomorrow to try them out since I opened a few beers while I was working
I am still curious about the transmission mounts. I would like to swap them out just for drill, but if its a major PITA then I will wait until I have a better reason to pull the trans.
Thanks again for the help!
Old 11-07-2009, 12:12 AM
AOW162435
Seared
AOW162435's Avatar
Very talented!
Andreas
Old 11-07-2009, 12:29 AM
shu
shu's Avatar
Thats impressive....nice job! Let us know about the tranny mount swap.
Old 11-07-2009, 01:36 AM
Basal Skull
Basal Skull's Avatar
From what I have been told by my tech, the AWD mounts can be done with the trans in the car, RWD easier to do when the trans is out. Have never looked/tried it myself though.
Old 11-07-2009, 11:07 AM
Jeff96-993
Jeff96-993's Avatar
I've got an RS tranny mount that's been sitting in my garage for 2 years just waiting for an answer to this question. Since I could never get a clear answer I've been waiting for the clutch to go and install at that time.
If it's possible to do it with the tranny in the car, I'll add to my winter project list!
Quick Reply: Transmission Mount Replacement
