The g50/31 Experience
As some of you know, I purchased a 993 RS g50/31 gearbox recently. I decided to pull the engine to install the following along with the gearbox:
- RS LWF
- RS Clutch
- Rear Main Seal
- Plugs
- Power Steering Belt
- Timing Chain Cover Gaskets
- Valve Cover Gaskets
Overall I'm really happy with the result. I've heard people claim that a regear feels like an extra 50hp. I don't agree, but it does feel like the gaps in the powerband have been minimized. In other words, the car doesn't pull much harder, but the gearbox allows you to always stay in the meat of the powerband where the car pulls the hardest. This was impossible with the /20 as the gaps were simply too wide. A good example is the 1st to 2nd shift. With the /20, the car always felt "off cam" after the shift, no matter hard high it was revved in 1st. This is no longer a problem now. There's one continuous thrust of acceleration. The net result is that the feels really quick everywhere.
Misc stuff:
- I like the LWF - no stalling even with a/c on and no noise at idle. But there is noise when accelerating at low rpms. To me the noise is not great, but it's worth the tradeoff.
- Unexpected benefit - the LWF makes it much easier for me to match revs.
- The /31 shifted smooth from the very beginning. I was expecting notchiness until it was broken in. Using Mobil Delvac.
- The tall 1st gear of the RS box is not really a big deal in traffic. You get used to it.
- What is harder to get used to is remembering to use 1st for more than starting off (2nd is pretty tall). Since my other car is also a manual and the 993 is not my daily driver, this is more of a challenge. However, having a usable 1st is a joy when you remember to use it.
- 6th gear doesn't seem short at all. In fact, I wouldn't mind if it were a bit shorter. IMHO, there absolutely no reason to retain the /20 6th gear on an NA 993. Way too tall.
Overall, I'm glad I spent the time and $$$. This is my "forever" car, so i'm not worried about recouping the investment.
Cheers,
Joe
- RS LWF
- RS Clutch
- Rear Main Seal
- Plugs
Misc stuff:
Cheers,
Joe
JMARCH, agree entirely with your G50-31 gearbox. I think the box would be even sweeter with shorter 2-6 gears, the tall 1-2 is good for track but a shorter stack would be better for the street, maybe not the freeway, but again you have another freeway driver. Of course your avitar is cooler that all this trivia, looks like China Hat?
Congrat Joe!!!
Just as I have imagined, it doesn't make the car pull harder, just be in the right rev for it to pull.
That ltw flywheel is something else huh? One blip of the gas pedal and the revs go soaring making it pretty easy to heel-toe. Oh yeah the noise, makes you think you engine turned to a clothes dryer filled with rocks.
Seems we have similar tastes in cars and bikes. But, you have a real RS - Wow!
Cheers,
Joe
Job well done.
I really appreciate your assessment of the g50/31.
Can you please explain/describe this noise at low rpms?
Thank you,
Bob-
Congratulations!
The obligatory gear comparison chart
The available acceleration at a given speed feels like a lot more hp, drive both your cars at the same speed in the same gear, which feels livelier?
for the most part they have but it still has the tallish 6.
I couldn't agree more, tastes vary but I like ~165 for a top in 6, you still have reasonble cruise rpm but the car is much more lively than /20 at all legal speeds. Most tracks around here you use 3, 4, 5 only Montecello has a long enought straight for 6. If you move 5 to 6 that is liveable but a little short.
Thanks to both you and Darrin for helping me source parts. FD Motorsports is a wonderful resource for us on this list. Mark and Darrin are very knowledgable (I didn't have to worry about getting the wrong parts), and went out of their way to remedy a problem (not their fault) that we ran into when I found a little problem with the LTW (see below). Glad I caught this before I installed everything
Congrat Joe!!!
Cheers,
Joe
Bill, no question the car is much livelier now. The point I was trying to make is that the car doesn't pull like a turbo, but the gearbox helps fill in the gaps the /20 exposes by letting the engine revs fall too low.
Beers, I have the stock shifter.
Andreas - I don't know what you are talking about
Cheers,
Joe
Cheers,
Joe
