The official PORSCHE 993 OBD II test drive
#31
BTW, today I decided to check my '97 M3 and it only has those 8 flags set. Per the OBDll reader manual the display "DONE" (see photo #2 above) will only display when all flags that the vehicles OBDII system checks and have set (passes). IOW, if the system checks 8 systems and only 7 have set then the text "DONE" will not display.
#32
could someone comment on the second column, "Load" of the OBD ll sheet from the first post?
I live in a very steep area, its either uphill or downhill from my home.
I'm having trouble getting the readiness codes to set and thinking maybe its that I need a flat area to run the drive cycle?
thanks in advance.
thanks in advance.
#33
thanks in advance.
thanks in advance.
#35
No, you have to let it cool down a bit. How long, I don't know. I suspect your ambient temps will impact how long it needs to cool. Shortest I've waited was 3 hrs. but if I was doing it now in our cool weather I would give 2 hrs. a try.
#36
I did. I actually did it three times in a row to make sure I covered it. And it did. Next time I only did it twice in a row. And it worked that time too. Perhaps next time I try it just once!
#37
I'll be unplugging my battery in a few days, I'll test it after that.
#39
I was just reviewing the doc in the 1st post, for cycle #3 (SAI) it requires an engine temp. between 12c and 60c which is 53F and 140F. Don't really know what impact that has on his question though.
#40
I'd love to hear definitively if I have to wait for any period of time before I start the second run. I'd hate to ruin it by waiting too long/not waiting long enough!
#41
I don't think that matters. I think they're just saying that the engine temp has to be in that range for that particular readiness test.
An easy way to verify one way or the other is to use a OBDII tester and follow what I did in posts 28 & 29. You can do the first run, leave the tester hooked up, shut the car off for a few min. and then start the car up and run it again. The tester will tell you if the readiness indicators set. If they don't after the second run then shut the car off and let it cool for a couple of hours and run it again.
I'll be happy to test it this w/e if the weather cooperates, I need to disconnect the battery anyway. My previous 993 Cab reset very easily, I'll see if this one is just as easy to do. Of course it helps that I have great roads near where I live to do this, I have 3 routes that I've run from my house, any one works fine.
You're not going to ruin the test by waiting too long, it just needs 2 complete/successful runs to set the readiness indicators. Personally I've run 1 pass on 1 day, let the car sit overnight and run the second run the next day and the RI's set after the 2nd run.
#42
I'm the proud original submitter of the "BMW Readiness Code Set Routine" and wanted to remind those that are interested that it was entered on our DIY forum a few years ago: https://rennlist.com/forums/993-1995...t-routine.html
Again, it has worked for me quite nicely for years. I have a laptop diag app that tells me the readiness codes/status which always confirms the routine's success.
I've just ordered the parts to finally end this foolishness with a SAI port cleanout (I hope!).
#43
#44
GOOD LORD! I just finished my 1st drive following the BMW sequence. It took me an hour and a half. It's tough to find suitable places to do this here in LA!
Here's today's questions. Can I wait until tomorrow to do it again, or do I have to start another driving sequence immediately (or within 4 hours or whatever)? Also the next time I start my car do I have to do the sequence to complete it? Or can I go get gas first? I've only got about 1/8 of a tank left and I have my doubts as to whether that's going to cut it or not.
#45
On my roads, 1/8 tank of gas would be plenty to make the 2nd run, however it sounds like you have a harder time finding those roads. This is my suggestion for you, I would do as much of the 2nd run as you can on your way to get gas. When you get to the station DON"T shut the car off, let it idle. Put whatever gas you need and then continue with the remainder of the 2nd. run. If you can't do that, just get your gas, take the car home, wait a few hrs. and then do the second run. Just don't take the car over 3k RPM on the gas run.
Best of luck.
