993 Forum 1995-1998
993 RS calipers ?
Old 03-22-2017, 06:40 PM
  #106
Silver Surfer
Silver Surfer's Avatar
Default RS Rear Brakes
Originally Posted by Bill Verburg
The correct bolts are 900.378.068.09 M12x1.5 x38mm caliper bolts x4, these ar 3mm longer than those used on normal 993
Thanks Bill, you are very generous with your knowledge!
Old 03-22-2017, 09:09 PM
  #107
mhm993
mhm993's Avatar
Sunset has the longer bolts in stock. (For some reason, the stock black caliper bolts always arrived in green coating but the tt bolts arrive w a red coating. )
I've been running TT/RS calipers for a number of years, for the benefit of larger rotors to help disapate heat, but w/ no changes to proportioning valve or any other changes. The car weighs 2975 and I run hancook dot slicks and pfc brakes. I'm extremely satified with the outcome.
Old 03-24-2017, 09:29 AM
  #108
cobalt
cobalt's Avatar
Received 1,925 Likes on 1,165 Posts
Originally Posted by 964TT
It's a 322/28 custom made for 964 to retain the handbrake. I'm mounting them in a couple of weeks and I'll post the details.
Originally the idea was to go with 993tt front/rear but after reading your info I'll be going 993rs rear.
Any idea what my brake bias will be with this setup? Close to the 1.5 number?
I am using the 322/28 with RS calipers rear. Any rotor we were able to make work at all required a custom hat and would not allow me to retain the handbrake on a 964 trailing arm. The bolts holding the hat to the rotor interfere with the handbrake and there is not enough clearance no matter how we approached it.
If you have a solution using these sizes on a 964 trailing arm I would be very interested in it.
Old 03-24-2017, 06:34 PM
  #109
964TT
964TT's Avatar
It seems I do, lets see if it all works out as planned. What p/v are you using with the 993RS rear setup?
Old 03-24-2017, 10:01 PM
  #110
MarinS4
MarinS4's Avatar
Has anyone considered just machining the TT rear calipers for larger pistons? It would be a great way to increase rear bias without the costs. I would opt for even smaller sizes than RS. Maybe a 28/32 split would be in between the two and offer a good compromise.
Old 03-25-2017, 02:33 AM
  #111
drb930
drb930's Avatar
+ 1,000,000
Just what I was thinking...
Old 03-25-2017, 02:35 AM
  #112
drb930
drb930's Avatar
If you are running a 965 rear arm there is a Cayenne 300 X 28 rotor that works, & has the parking brake drum.
Old 03-25-2017, 12:26 PM
  #113
Bill Verburg
Bill Verburg's Avatar
Geoffry Ring and I talked about doing this years ago but never went forward w/ it. If you wanted an intermediate bias between tt and RS you'd want to use the normal 993 rear 30/34 pistons.
The 993RS bias is only slightly more rear ward than that of pre '84 911.
As I said I have it on both my cars, on the '76 C3 there isn't even a p/v. This setup works great on the street and on the track. for track use the more rear bias that you can use the more of the load is taken off the front, that's a good thing.
lower car, stiffer suspension and effective lsd are all pluses to take advantage of more rear bias.
the issue w/ this setup on 964 is the parking brake not bias.
Old 03-27-2017, 01:13 PM
  #114
trophy
trophy's Avatar
Thtas a great idea, Doing that would not be that expensive overall, as you would only machine one bore from 28 to 32. 4 Pistons and a set of seals and you would be off...
Old 03-27-2017, 11:53 PM
  #115
MarinS4
MarinS4's Avatar
That's kinda where I was going with it. The differential bore would also help pad taper. Adjust pad compound to taste from there.
Bill does make a compelling argument when comparing front to rear splits in the earlier cars though. I almost think the TT bias was another way Porsche tried to tame the widow maker reputation.
Quick Reply: 993 RS calipers ?
