Does anyone know the minimum thickness spec for 993 rotors?
I suspect it's about time to do a complete brake job on my car, but I'd like to measure the rotors just to be sure (and just 'cause I'm curious). I've searched and searched but can't find any mention of the minimum thickness spec for rotors. Anyone know?
I normally run 'em until the rotors look like pie tins and I have to use the e-brake to stop the car, but in this case I'm trying to be a more conscientious motorist. I measured them, and the fronts are right at 30mm. Time for new rotorz.
Oh yeah, I'm also re-gearing the transmission and installing a limited slip and RS clutch/flywheel, among other things. But I'll save all of that for another post.
All Porsche rotors have a 2mm wear limit from new, so if the discs start at 32mm replace them at 30, for the rears at 28mm/24mm you bin them at 26/22 respectively.
