RIVI BLUE CAB - My RSD project many pics
A couple of years ago I bought a used RSD for around $250.00. I got it on Craigslist and all the guy told me is that it was Cahmere Beige. Once it delivered I saw that someone had cut 2 holes in it for 10" subs. I never saw the holes as they were covered by the carpet. It was still a good deal and I knew that I would be using it for another project anyway. So here it goes.
This is the way I got the RSD
You can see here that the PO had cut the holes for the sub woofers. Not a big fan of the holes. They will be filled here shortly.
Here I have removed all the doors and carpet from the RSD. Not much to these things. I still think it would be hard to replicate.
With all the carpet, doors and hardware removed I am ready to trace the pattern for the 1/4" Birch panel that will cover the sub woofer holes.
I clamped the 1/4" Birch panel to the RSD and traced out the exact pattern. Once the pattern was traced out off to the scroll saw I went. You can see here the new top installed giving a level surface for the new carpet.
To secure the new Birch panel on the RSD I used construction adhesive on the RSD part and the Birch panel.
On the Birch panel as well. Couple of cigs to the left. Don't tell the wifey
Now that the two panels have been mated I screwed them together for extra strength. Screwed and glued for a better mounting surface.
This is the old carpet laying on the new black Sliverknit. When you are doing this you want to cut a rough pattern leaving a lot of extra carpet. You do the final trim when gluing it down.
The next pic is mounting and stapling the carpet. I stapled the carpet from the underside as that is the way it came from the factory. It is also glued as well. The glue I used was the 3M Spray Adhesive.
Here the top is done and looking good
As you can see from the pictures the doors are Cashmere Beige. I am going to dye them black to match the interior.
Here is a picture of the door that has a small cut. I have sanded the vinyl and am getting ready to fill in the imperfections.
The doors were completely disassembled and taped off before the dying began. I used SEM Landau Black. A great match. The color code is 15013.
This is the backside of the door completed.
Here is the finished front door.
These are the "roll bars" for a lack of better terminology. I sanded them down with 180 grit and put a new fresh coat of black on them. Once they dry we are ready to install the RSD.
The RSD is done and mocked fit in the car. Looks a lot better from where it started. I did all this myself for $36.00 in parts and a good long day to complete.
And a thanks goes to Andreas for the help in posting this (text between the pics). Owe you a
Mike
Mike
Mike - When I did my RSD mod a few years ago, I removed the tan vinyl covering off the bin doors and replaced them with black leather (my RSD is tan carpet with black bin doors to match my tan/black two-tone interior). The bin doors are easily disassembled and recovering them is not a difficult job.
Not sure if your RSD came out of a cab but if it did then there should be the solenoid remote activated locks underneath. I haven't gotten around to figuring out the wiring but I'll get around to it one day...automatic locking bin doors would be great to have for time I leave the car parked with the top down.
www.gahh.com
I got my Sport Seat covers from them as well. I have used them many times in the past. A great company to deal with.
Mike
Mike
I disassembled the doors for dying. I thought about recovering them, but my punch list is forever long and I have to keep that in mind as well as costs. This car has not been cheap and is taking a long time. My interior is all black. I am also putting in a new carpet set. This will take a lot of time as well.
The RSD does have the remote activated locking mechanism (didn't they all?) There was no harness in the car as it came with the seats in the rear. I may get with you on the diagram for wiring it up, but that may be a weekend project down the road.
Mike
Mike,
You don't by any chance still have the template that you used to cut the top piece do you? I would be interested in grabbing that from you as I am thinking about crafting my own RSD. PM me if you still have it. Thanks!
Regards
Kevin
Regards
Kevin
