993 Forum 1995-1998
Idle Adjustment
Old 01-25-2009, 09:41 PM
captain911
captain911's Avatar
Default Idle Adjustment
Hello Fellow 993 Owners,
Just wondering if there is any way to adjust the warm idle on a 1998 993 S?
Based on the 3 prior 911s I have owned, I thought the "normal" idle was 750-800 rpm +/-. My 993 will dip will at warm idle and the car will shake for a second and then rebound to about 600rpm or so. Rather annoying so I wanted to see if there was anything I could adjust. I have recently cleaned the ICV.
Thanks for any assistance.
Tim
Old 01-25-2009, 09:59 PM
BobbyT
BobbyT's Avatar
You may want to clean the ISV. See here for more details:
http://www.pcarworkshop.com/index.ph...-_ISV_Cleaning
Old 01-25-2009, 10:02 PM
captain911
captain911's Avatar
Sorry I called it the ICV that I cleaned. It was the ISV.
Thanks.
Old 01-26-2009, 12:07 AM
black ice
black ice's Avatar
Search for ISV and idle together, because I think there is a set screw epoxied inside the ISV that you can adjust.
But to tell you the truth, I'd fix whatever your problem is correctly.
Old 01-26-2009, 12:40 AM
TheOtherEric
TheOtherEric's Avatar
Vacuum leak?
Old 01-26-2009, 09:42 AM
cabrio993
cabrio993's Avatar
Originally Posted by TheOtherEric
Vacuum leak?
+1
Quick Reply: Idle Adjustment
