993 Forum 1995-1998
Blackstone Laboratories' Oil Analysis
Old 06-25-2014, 01:20 PM
  #46
Falcondrivr
Falcondrivr's Avatar
I'm feeling pretty good about my report that came back today. Anyone see anything worrying that the Blackstone guys didn't?
Old 06-25-2014, 01:38 PM
  #47
NYC993
NYC993's Avatar
And you run this car on the track? Amazing averages for iron/copper. I gotta try this oil next time.
Old 06-25-2014, 11:10 PM
  #48
Matt Lane
Matt Lane's Avatar
Just me, or is the image removed?
Old 06-26-2014, 11:51 AM
  #49
Falcondrivr
Sorry Matt, I moved it to another album and photobucket linky was old... Fixed.
Old 06-26-2014, 01:41 PM
  #50
randytrish
randytrish's Avatar
I've just received my first sample kit from Blackstone. I know that the oil needs to be up to temp and circulating, but where do you pull your sample from?
Old 06-26-2014, 02:01 PM
  #51
Paul902
Paul902's Avatar
Randy, I sample my oil when I am changing the oil. I just fill the bottle from what is drained from the car. If you want to sample without changing the oil, you can crack open the dry sump drain plug and catch enough oil from it to fill the sample bottle.
Old 06-26-2014, 02:03 PM
  #52
Falcondrivr
When you change your oil, just put the container into the stream coming out of the tank. You want it mid-drain if possible so wait a few seconds and then take the sample. Wear gloves...
Old 06-26-2014, 02:38 PM
  #53
ilko
Agent Orange
ilko's Avatar
I've taken a sample off my old C4S, without changing the oil. Just place a long tube all the way down the oil filler neck and pull some oil using some suction.
Old 06-26-2014, 04:08 PM
  #54
crg53
crg53's Avatar
Shouldn't you take the sample BEFORE the oil goes through the filter. I would think oil taken from the engine case drain plug will give a better indication of contaminants in the oil.
Old 06-26-2014, 06:40 PM
  #55
NYC993
NYC993's Avatar
Interesting point...only one way to verify.
Old 06-26-2014, 10:11 PM
  #56
randytrish
randytrish's Avatar
I'm wanting to pull a sample without doing an oil change. I've only driven about 3-4k miles since my last oil change. I wanted to pull a sample to see...well just to see what it says. I wasn't sure of the best place to get a sample. I'll try and go out in the morning for a drive and get one.
Old 06-28-2014, 12:02 AM
  #57
jessl
jessl's Avatar
Blackstone sells a neat little pump and hose, which is what I use to pull samples.
Cheers,
Jess
Old 06-28-2014, 05:51 PM
  #58
KNS
KNS's Avatar
There are a couple of different ways. You can very carefully unscrew the engine drain plug - but not all the way out, of course. Just back it out and tilt it ever so slightly so you get a tiny stream to fill a sample jar.
The sample is also coming straight from the engine in this manner.
Old 06-28-2014, 06:07 PM
  #59
FlatSix911
FlatSix911's Avatar
Cheers, Jess
http://www.blackstone-labs.com/vacuum-pump.php
Old 07-24-2014, 09:52 PM
  #60
Eurotrio
Eurotrio's Avatar
I'll pitch in to the discussion.....here is my oil report. Really interested to find out what could be causing such high Copper result
Quick Reply: Blackstone Laboratories' Oil Analysis
