Anyone use Redline Oil 75W90 NS in thier transmission?
I just got off the phone with Redline Oil. They recommended their 75W90 NS oil for the G50/G96 transaxle.
Anyone tried this? Results?
Andy
75W90 NS
This GL-5-type geal oil doesn't contain the friction modifiers for limited-slip hypoid differentials. This makes the transmission synchronizers come to equal speeds more quickly, allowing faster shifting and much easier low-temperature shifting. Can also be used in racing limited-slip differentials where weak spring design causes too much wheel spin.
Andy
75W90 NS
Lifetime Member
Lifetime Member
I tried it and the fluid didn't do too well for me during winter time, after trying several fluids the last fluid I tried was thr Mobil 1 Delvac which I was completely satisfied with the result.
http://www.lufteknic.com/Merchant2/m...ode=lubricants
FWIW...the shop I use only puts the redline in...I just put it in last weekend and have not noticed anything different positive or negative, which I guess is good because it shifted/ran good before.
I just had mine done with Amsoil 75-90 & it feels great!
I'm also a Redline guy, in the my EVO I had to mix the 75-90 with some MTL to make the cold shifting nicer. MTL was the ONLY gear lube to use the BMW Trans.
I too didn't like the feel of the Redline and put Delvac 1 in my G50 - I stock it just for that reason and leave the Swepco 201 for all the earlier trannies.
