How hard to fix this?
Has anyone had this problem?
When I was pulling my battery tender out of the lighter, it pulled the lighter out of the dash with it. The metal receptacle came out, but the plug that hooks on to the back of the receptacle is now dangling behind the dash. I can reach through the hole and grab it, but it is too big to fit through the hole. Hence, I can't reattach it. It looks like the dash needs to come out. That seems like an extreme measure just to reattach the lighter. Plus, this is the turbo S and everthing is leather, including the screw covers, so chances are I will mess something up in the process.
Has anyone had this problem and know how to fix it? What is the minimum I need to take out to get access behind the part of the dash that has the lighter in it? Any suggestions are much appreciated.
I'd also like to know as I discovered when trying to use an FM iPod adapter that my lighter isn't hooked up at all. I have just the lighter insert and cannot even see any wires to attach.
Seared
No idea how to gain access, but I would suggest looking into a way to hardwire a set of leads directly to the battery. Once attached, you pop the trunk in order to plug your tender into the harnes attached to your battery.
I've worried about the lighter socket for a while, as I have the Porsche maintainer and use the lighter socket.
Andreas
Andreas
I would start by removing the radio, and cover the radio with a towel and wrap the whole in a plastic bag.
you do not want the radio chassis scrathing anything while dangling there.
insert your left hand facing upwards in the radio emplacement.
With a long plastic straw in the right hand, push the lighter base all the way in until you grab it with the
left hand. Now pull gently towards the outside. When you have enough access, leave the cig lighter base
dangling in the radio opening (even inside). Now insert from the cig lighter opening, an electric cable far inside, and
catch it with the left hand. Now, tape the electric cable to the cig lighter connection.
Disconnect the cig lighter connection.
Pull gently on the electric cable, while liberating the path with your left hand, until the cig lighter connection
pops out from the dash hole.
Adjust the base moustaches (widden) to help the base grip strong.
remove tape from the cables and hook the cig lighter.
Insert the cig lighter perpendicularily into the dash(retaining ring). tadam!
Try pulling the stereo head unit out... which is way easier than the whole dash. I just did a major stereo upgrade, but can't recall if this allows access to the back of the lighter. Worth a try...
geolab, sound reasonable. I thought about going throught the glove box, but that didn't look like it would work. I'll give it a shot and let you know. Is removal and reinstall of the radio straight forward? Thanks.
Okay, so perhaps I am an idiot, but it is not obvious how to get the radio out. On the 964 it is easy, because the lower dash is small and you can see the radio bracket from underneath. In the 993, I can't touch or see any part of the radio bracket from below. Help!
Never mind. I think I have it figured out. It's not done yet, but looks pretty easy.
Garth S, Thanks. I was sticking all sorts of things in those slots and couldn't fit my hand behind to push anyway. I just bought those from ebay.
Meanwhile, I just noticed that there is a 12V socket under the dash that I can use for the charger instead of the lighter anyway. I didn't know it was there. Apparently, having the lighter disconnected makes the 12V outlet not work, too, though, so I still need to fix this.
I was unplugging an air compressor and the lighter receptacle came out with it. The plug is dangling behind the hole in the dash board. The car is in winter storage mode (excepting today, it feels like spring here), and I charge the car though the lighter. So I need a quick fix for this or a new charger that Xonnects easily to the battery ASAP. Do I really need to yank the radio to reconnect the lighter socket?? I don't have small hands... Is there some quick fix here, it's so close? Alternatively got any recommendations for a good charger I can find somewhere quick? Doh. Thanks in advance.
If you go the route of a new charger, I have 3 of these and have been using for a number of years with no problems.
https://www.amazon.com/CTEK-56-353-1.../dp/B000FRLO9Y
They also sell a connecter that plugs into the lighter receptacle which is what I use. It's actually a little loose, as the 993 lighter receptacle is bigger than most. Weird, first time I saw a thread on the lighter receptacle getting pulled out.
