Key Stuck in Ignition...
Originally Posted by chris walrod
Wonder if the steering lock has something to do with this problem? does the key turn easier when wiggling the steering wheel?
Originally Posted by Thaddeus
That sort of improvisational thing would be acceptable if it was a Buick or some such trash, but not a Porsche. Fix it!
Note the position of the shift **** button. If it is not protruding all the way up, it means that you have not fully engaged "P" and the key won't come out. Even a slight misalignment will cause this problem. Easily fixed though, make sure it is all the way forward and there is nothing impeading the shifter movement.
