993 Forum 1995-1998
Battery Died, Replaced Battery, Car Won't Start, No Immobilizer Light HELP
Old 11-10-2006, 02:18 PM
Chuck W.
Chuck W.'s Avatar
Default Battery Died, Replaced Battery, Car Won't Start, No Immobilizer Light HELP
The battery was a Red Top and over three years old, so I wasn't too shocked when I came out to a dead battery Tuesday. I replaced the battery and all appeared fine. However, when I went to start it I noticed no immobilizer light on the dash and when I hit the remote the red lights on the door did not flash. I tried several DIY things including the manual activation of the immobilizer and putting in the spare DME and trying another remote. Still no immobilizer lights.
Any ideas before I tow it to the shop? TIA
Old 11-10-2006, 02:22 PM
95 C4 993
95 C4 993's Avatar
Replace the battery in the immobilzer. Then buy 2 extra batteries and put them in your car with a small phillips screwdriver.
Old 11-10-2006, 02:24 PM
95 C4 993
95 C4 993's Avatar
I have been down this road a couple of times and low and behold, I had bad batteries in both immobilizers. Not saying its the answer but its worth a shot.
Old 11-10-2006, 02:28 PM
geolab
geolab's Avatar
What kind of battery did you get? is it a porsche battery?
If so, in the EU the porsche batteries come uncharged and you have to charge them.
Check if the new battery is charged, if its a porsche one.
Old 11-10-2006, 02:33 PM
Slow Guy
Slow Guy's Avatar
I don't think this is a Immobilizer Remote problem.
Was the battery fully charged when you installed it? I would suspect that the battery cables are not making full connections. I don't THINK the DME relay would behave like this but I'm not certain.
Also, could there be a fuse/relay for the immobilizer itself?
Old 11-10-2006, 02:37 PM
Randy 1
Randy 1's Avatar
Call me crazy, but isn't there a code inputted by turning the key on and off? I remember I was having the same problem after the car had sit for 3-4 years, even with a fresh battery. I had a friend come over, and I hazily remember some sort of fancy code using the key...
edit: ah ha, I assume that's what "manual activation of the immobilizer". Well, then, I'm stumped.
Old 11-10-2006, 02:42 PM
Chuck W.
Chuck W.'s Avatar
I bought another Red Top and put it on the charger all night. Everything in the car powers up strong. The battery if fine. I just checked both remote batteries and they both were strong.
Old 11-10-2006, 02:58 PM
geolab
geolab's Avatar
Now that you have the workshop manual, please refer to page 1456 to 1481 alarm system diagnosis.
there is a step by step diagram, I am sure your answer is in there
Old 11-10-2006, 03:58 PM
95 C4 993
95 C4 993's Avatar
Mine is a 4 digit code. What the hell, give mine a shot
Immobilizer Code 3688
Old 11-10-2006, 04:29 PM
Chuck W.
Chuck W.'s Avatar
Good point....I'll see if I (a non-tech) can figure it out.
Old 11-10-2006, 07:38 PM
Chuck W.
Chuck W.'s Avatar
Hah,,,,great stuff. But not enough for me to figure this out.
Old 11-11-2006, 08:41 PM
Chuck W.
Chuck W.'s Avatar
OK....I go out and reconnect the battery....The car starts.....I pull 5 feet forward and it dies. Again, no immobilizer light. Try the battery disconnect several times during the day and the last time the immobilizer light comes on and the car fires up.
I figured it out. There is a problem I can't solve so it'll get towed in next week.
I will post what the problem was.
Old 11-14-2006, 11:01 AM
Slow Guy
Slow Guy's Avatar
Chuck, did this get resolved? What was the cause? IMWTK
Old 11-14-2006, 10:51 PM
Chuck W.
Chuck W.'s Avatar
I wish...My machanic is busy and can't see it until the end of this week or the first of next week. I'll post the problem when he figures it out.
Old 07-23-2015, 09:15 PM
24FPS
24FPS's Avatar
Default hi, Chuck...
love it if there's a reply or another thread with what solved Chuck's problemo.
had similar issue with my cab & a new DME seemed to solve. but I'm also looking into installing new ground straps off battery & starter. prob was intermittent for me.
new battery & alternator... THEN 3rd DME worked until a snafu today.
993 cab will go to Indy ASAP.
Quick Reply: Battery Died, Replaced Battery, Car Won't Start, No Immobilizer Light HELP
