View Poll Results: How often do you add a quart of oil?
Less than 500 miles
11
5.85%
500-1000 miles
21
11.17%
1000-1500 miles
41
21.81%
1500-2000
30
15.96%
2000-3000
33
17.55%
3000-5000
26
13.83%
over 5000 (or never)
26
13.83%
Voters: 188. You may not vote on this poll
Poll: How often do you add a quart of oil?
Originally Posted by aof
Since we are on the subject, is it true that filling the engine up to the top mark on the dipstick encourages oil consumption?...where do people fill up to? ...
He says to keep the level no higher than the half point on the dipstick then add 1/2 liter when needed.
Prevents leaks from the one way check valve... he claims.
Monique, I wondered about that. I noticed (twice now) that it seems to burn it fairly rapidly (1000miles) down to 3/4 mark and then stabilizies. Thanks for the response
To answer the question about the valve covers- absolutely! I could drop a half a quart in a couple of days through my lower covers. When I changed them out I discovered my RMS leak. Oh well, I have been planning to do a LWFW and clutch anyway.
Is there any body interested in the relationship between miles on the engine and oil consumption? Maybe one of you creative (web) guys could start a new thread?
Thanks, Fred
Thanks, Fred
To those who burn 1qt < 1000 miles, what do you attribute your oil usage to? Leaks big or small? Hard driving? Valve guide wear? Or is the argument, "its within factory spec"?
The original owner of my car told me he almost never had to add oil between oil changes, which, of course, I (&my PPI Mechanic) took with a grain of salt.
Almost feel like something must be wrong with the car.
me too on low oil use
Me too.....feeling nervous.... Castrol 5w-50. No gas exchange being noted afaik either.....about a quart at most at 5k...then I change the oil anyway. No leaks anywhere (mechaninc checked carefully one month after the engine was show prep clean).
Tire wear is getting me though.
I Ran 2100 miles on my last Highway Holiday before adding a quart.
I always keep the dip stick near Full.
I have never tried to keep it at half on the stick.
I just ran about the same with Highway City combined - ironically this is after changing the Resonance Gasket and Drilling the SAI Ports.
So oil consumption HAS Improved .
Guess part of this is the Resonance Flappe Gasket being Cleaned Up and Replaved?
SAI Drilling Hmmm - Thoughts?
Confusing.
All of this with 100,000 mILES ON A Rebuilt Top End
And Yes, when I can I do Open her Up!
Confusing.
I started this driving season in march at 63,137 miles with a fresh oil change. Just had the oil changed again today at 67,357 miles. I used approximately 1 1/2 litres between oil changes. I'm pretty happy with that. No leaks by the way.
