993 Forum 1995-1998
OBD II Porsche specific trouble codes
Old 04-02-2003, 12:55 PM
96P993
96P993's Avatar
Post OBD II Porsche specific trouble codes
I am wondering if there are any..I have a book with the generic codes but wanted to know if there are specific codes for Porsche only....Thanks
Old 04-02-2003, 06:13 PM
p_carfan
p_carfan's Avatar
Post
Go to My-Porsche.com WKD-483-420 OBD II Diagnostic Manual, 911 Carrera (993) 1996-98 $58.31. If you get it, let me know what you think. I'm considering the OBDII software for the PDA. Could be very Interesting.
"May God Bless Our Troops"
Good Luck!
Steve
Old 04-02-2003, 06:24 PM
96P993
96P993's Avatar
Post
I wonder if anyoone owns this book..does it have any insight into the "typical" check engine light that seems to plague so many people..
Old 04-02-2003, 07:05 PM
rattlsnak
rattlsnak's Avatar
Post
I dont know about the book, but every manufacturer has Specific codes. All 'POxxx' codes are the same for everyone, but all codes that have the second digit other than 0 are manuf. specific, like P1xxx or P1187. The government mandates that all emission related fault codes be specific. Like a P0306 is a misfire on cylinder number 6, for every car (if equipped of course). However a P1615 is a powertrain fault as well, but not related to tailpipe emissions, and therefore a P1615 will not be the same from car to car. Example would be the PPS (pedal position sensor) on a Corvette, that code would be something like a P1xxx, and no other car has that, so it is specefic. Also includes T or B codes for trans and body codes, as well as the other 16 modules most cars have now.
Old 04-02-2003, 07:07 PM
rattlsnak
rattlsnak's Avatar
Post
Forgot to mention the most common reason for Check Engine light to be on, is a P04xx something, which is an Evap leak, or someone left the gas cap loose, or filled it up with the car running, and it just happen to run the evap monitor at that point.
Old 04-03-2003, 12:28 AM
96P993
96P993's Avatar
Post
If Im not mistaken the most commone engine code for the 993 is 300-306 which is misfire of a cylinder. This seems to come up very often and have many fixes (temporary and permanent). Kim that would be great if you would do some looking..I would be very interested to see what the book has to say about the misfire. It is very vague and could be many different problems..Thanks
Old 07-21-2011, 03:00 PM
Coleman
Coleman's Avatar
[Trouble Code Descriptions]
[ABS5]
;Anti-lock/traction control trouble codes
11=Control unit faulty
12=Stop light switch
13=Incorrect gearwheel
14=Intake valve
15=Switch-over valve
17=Throttle (TP) information
21=Front left speed sensor, signal unplausible
22=Front right speed sensor, signal unplausible
23=Rear right speed sensor, signal unplausible
24=Rear left speed sensor, signal unplausible
25=Front left speed sensor open, short + or gnd
26=Front right speed sensor open, short + or gnd
27=Rear right speed sensor, open, short + or gnd
28=Rear left speed sensor, open, short + or gnd
31=Front left inlet ABS valve, open, short + or gnd
32=Front left inlet ABS valve, open, short + or gnd
33=Rear inlet ABS valve, open, short + or gnd
34=Rear left inlet valve, open, short + or gnd
35=ABS valve Exhaust FL, open, short + or gnd
36=ABS valve Exhaust FR, open, short + or gnd
37=ABS valve Exhaust RL, open, short + or gnd
38=ABS valve Exhaust RR, open, short + or gnd
39=Valve relay, open, short + or gnd
40=Return pump, open, short + or gnd
[H05]
;Climate control trouble codes
11=Inside temperature sensor
12=Left mixing chamber temperature sensor
13=Right mixing chamber temperature sensor
14=Evaporator temperature sensor
15=Rear fan temperature sensor
21=Oil cooler temperature sensor
22=Defrost flap motor
23=Footwell flap motor
24=Fresh air flap motor
31=Left mixing flap motor
32=Right mixing flap motor
33=Left heater blower motor
34=Right heater blower motor
41=Condenser blower motor
42=Oil cooler blower motor
43=Rear blower motor speed 1
46=Rear blower motor speed 1
44=Rear blower motor speed 2
47=Rear blower motor speed 2
45=Inside sensor blower motor
[H06]
[M04]
;Motronic trouble codes
11=Power supply, DME, high
14=Engine temperature sensor 2
15=Throttle Potentiometer
16=Throttle Potentiometer
18=RPM Signal
19=Speed signal / Speedometer
21=Hot-wire mass air flow sensor
22=Oxygen sensor (Sensor signal)
23=Oxygen regulation / stop (intake air leak?)
24=Oxygen sensor short to+ or 0 Volts
25=Intake air temperature sensor
26=Ignition timing change
27=IAC opening/closing winding
28=IAC opening/closing winding
31=Knock sensor 1
32=Knock sensor 2
33= Control unit faulty, Knock computer
34=Hall signal
36=Idle CO potentiometer
41=Control unit faulty
42=Fuel pump relay (DME relay)
43=Tank ventilation valve
44=Auxiliary air pump relay
45=Warning lamp Check Engine
51=Injection valve 1
52=Injection valve 2
53=Injection valve 3
54=Injection valve 4
55=Injection valve 5
56=Injection valve 6
67=Ignition final stage
68=Ignition final stage
69=Ignition final stage
[M06]
18=RPM Signal
31=Knock sensor 1
32=Knock sensor 2
34=Hall signal
[B02]
;Airbag trouble codes
2=Driver ignition circuit to + or 0 V
5=Passenger ignition circuit to + or 0 V
17=Battery voltage low
19=Airbag Warning Light to + or 0 V
73=Short circuit ignition pills
76=Control unit fault cannot be erased
77=Result message cannot be erased
1=Fault memory cannot be erased
6=Fault memory cannot be erased
7=Fault memory cannot be erased
12=Fault memory cannot be erased
13=Fault memory cannot be erased
14=Fault memory cannot be erased
15=Fault memory cannot be erased
16=Fault memory cannot be erased
18=Fault memory cannot be erased
23=Fault memory cannot be erased
48=Fault memory cannot be erased
49=Fault memory cannot be erased
50=Fault memory cannot be erased
51=Fault memory cannot be erased
52=Fault memory cannot be erased
53=Fault memory cannot be erased
54=Fault memory cannot be erased
55=Fault memory cannot be erased
56=Fault memory cannot be erased
57=Fault memory cannot be erased
58=Fault memory cannot be erased
59=Fault memory cannot be erased
60=Fault memory cannot be erased
61=Fault memory cannot be erased
62=Fault memory cannot be erased
63=Fault memory cannot be erased
65=Fault memory cannot be erased
67=Fault memory cannot be erased
68=Fault memory cannot be erased
69=Fault memory cannot be erased
70=Fault memory cannot be erased
71=Fault memory cannot be erased
72=Fault memory cannot be erased
[B03]
04=Driver ignition circuit
05=Driver ignition circuit
10=Passenger ignition circuit
11=Passenger ignition circuit
03=Battery voltage low
01=Airbag Warning Light
02=Airbag Warning Light
01=Fault memory cannot be erased
70=Child seat detection
71=Child seat detection
72=Child seat detection
100=Control unit faulty
20=Driver ignition circuit
21=Driver ignition circuit
36=Driver ignition circuit
26=Passenger ignition circuit
27=Passenger ignition circuit
39=Passenger ignition circuit
73=Child seat detection
101=Control unit faulty
102=Control unit faulty
103==Control unit faulty
[I00]
;Alarm System trouble codes
12=Voltage failure term 30, active alarm
13=Voltage failure term 30 during output
14=Position of drives unplausible
15=Door open during activation
16=Engine lid open during activation
17=Luggage lid open during activation
18=Glove box open during activation
19=Input 2 to gnd during activation
20=Central locking system button closed during activation
21=Input 1 to gnd during activation
22=Input 3 to positive during activation
23=Fault memory
24=Fault memory
25=Fault memory
26=Fault memory
[I01]
23=Fault memory
24=Fault memory
25=Fault memory
26=Fault memory
Old 07-21-2011, 09:19 PM
henkinc
henkinc's Avatar
I looked in vain for the most likely CEL code, whichI believe is P1410 or 1411 - left hand or right hand Secondary Air Injection fault. The infamous clogged SAI port issue. Is it in there someplace??
Quick Reply: OBD II Porsche specific trouble codes
