993 Forum 1995-1998
Where to grab high current 12v for an amplifier?
Old 09-25-2013, 08:04 AM
marcus550
marcus550's Avatar
Default Where to grab high current 12v for an amplifier?
I'm installing an amp under the passenger seat this weekend. Where is a good place to grab a high-current 12v from and how to run it through the sealed bulkhead? Any suggestions?
Old 09-25-2013, 08:36 AM
tracke30m3
tracke30m3's Avatar
You definitely want to get power straight from the battery when installing an amp.
There should be a rubber grommet in the corner of the passenger side fire wall near the hood strut where you can pass the cable thru.
Don't forget to install a fuse as near to the battery as possible.
Old 09-25-2013, 08:08 PM
M. Schneider
M. Schneider's Avatar
+1 ... At battery with ATC type fuse holder. (8ga wire as example)
There is a grounding post under the seat also. The gauge of wire is best to be the same gauge for both 12v + positive and - negative.
Which model audio amplifier are you installing?
Old 09-25-2013, 09:55 PM
Kika
Kika's Avatar
+1. Direct from battery, with sufficiently gauged wire, fuse and soldered connections.
Quick Reply: Where to grab high current 12v for an amplifier?
