Quick fix for falling foam
Old 12-29-2005, 02:33 PM
jimq
Burgled
jimq's Avatar
Default Quick fix for falling foam
While I had my airbox off to do the shocks I made a quick and easy fix to the foam falling from above the engine. From what I understand it takes a engine drop to replace this. Mine was ok except at the front edge so I bought a piece of 1 1/2" x 1/8" aluminum bar at Home Depot for about $8. I cut it to about 30" long but this can vary. I bent it to approximatly the curvature of the mounting area. Use something round like a pipe and you will get a better bend. I lined it up and marked the hole locations and drilled the bar about 1/2" in with a 1/4" drill bit. I elongated the holes to get a better fit. I will probably take it off and paint it flat black and nobody would know it wasnt suppose to even be there. Easy 30 minute fix until and engine drop.
jimq is offline
Old 12-29-2005, 02:46 PM
DarrylH
DarrylH's Avatar
What a great idea. My tatty foam has bugged me since the day I got the car. Excellent!
DarrylH is offline
Old 12-29-2005, 03:24 PM
Euromagination
Euromagination's Avatar
Definitely a good idea. My foam is starting to do the same thing and it sucks! I wanted to just rip it all out the other day as I looked at it, but I managed to control myself. Maybe I'll try this idea instead.
Euromagination is offline
Old 03-15-2006, 10:02 PM
bhensarl
Jarhead
bhensarl's Avatar
Great idea, Jim. This is going to the DIY forum.
Brian
bhensarl is offline
Old 03-31-2006, 05:55 PM
zdek
zdek's Avatar
I just tore all of mine out - It cleaned it up a lot and I don't have to deal with all that black dust anymore. I'll get a new one in there when I drop the engine.
zdek is offline
Quick Reply: Quick fix for falling foam
