Engine removal
Old 05-09-2005, 05:10 AM
Toga
Toga's Avatar
Default Engine removal
Hi John, Hi Brian!
this DIY page is a great idea!
I'm not a mechanic. This winter I pulled my engine out for the first time, and did a lot of "preventive maintenance" on it. This was a loooooooooong topic with 12 threads on my work with a lot of pictures and details. I'm not sure my technical english was always right to explain things, but here are the different links in the correct order.
I hope you'll find it useful.
Before I start
https://rennlist.com/forums/993-forum/174810-before-i-start.html
Engine removal phase 1 (Bumper)
https://rennlist.com/forums/993-forum/175041-engine-removal-phase-1-bumper.html
engine removal pase 2
https://rennlist.com/forums/993-forum/175044-engine-removal-phase-2-a.html
engine removal phase 3
https://rennlist.com/forums/993-forum/175200-engine-removal-phase-3-a.html
engine removal phase 4
https://rennlist.com/forums/993-forum/175202-engine-removal-phase-4-a.html
engine removal phase 5
https://rennlist.com/forums/993-forum/175358-engine-removal-phase-5-a.html
distributor chain cover seal replacement
https://rennlist.com/forums/993-forum/176050-distribution-chain-cover-seal-replacement.html
engine removal follow up (ignition cables)
https://rennlist.com/forums/993-forum/176597-engine-removal-follow-up-and-ignition-cables.html
engine removal follow up (LWF)
https://rennlist.com/forums/993-forum/178373-engine-removal-follow-up-lwf.html
engine removal update (engine is in)
https://rennlist.com/forums/993-forum/186548-engine-removal-update-engine-is-in.html
engine removal update (oil return tubes)
https://rennlist.com/forums/993-forum/187493-engine-removal-update-oil-return-tubes.html
engine removal update (happy end)
https://rennlist.com/forums/993-forum/187640-engine-removal-update-happy-end.html
Toga is offline
Quick Reply: Engine removal
