Musicar Northwest Group Buy — 991 High-End Tweeter Upgrade
#211
Platinum Sponsor
Definitely thoughts... and some R&D in the works. Working with factory amplifier power and the lack of a real EQ, we need to make sure whatever is done there is a worthy improvement. I want to have a solution, just need to take the proper time to be certain it's the perfect one for that application.
#213
I went on and disconnected it without testing the sound with it in place, I don't think it makes sense to have different speakers for the high range working at the same time, you don't really need a center channel for stereo sources and the different characteristics would make the integration with the dynaudio tweeters impossible.
you can always try with the cloth and book on top and decide for yourself, I didn't even do that
#216
Platinum Sponsor
Make sure when you Bose owners are testing the "center channel delete" option that you turn surround on and off. With surround on a lot of the info is sent to that channel, so typically removing the center means forfeiting the "surround" option – which is a worthless option anyway(imho).
#218
Originally Posted by Joec500
@Nick,
Do you happen to have recommended settings for the addition of these tweeters on a relatively stock system? (Bose)
Here are my settings:
Sound:
0 Base
+2 treble
0 balance (moved from 2 driver)
2 rear Fader
Surround off
Option:
Linear checked
#219
Platinum Sponsor
No worries Mike, I know everyone's anxious to get these in their hands. That said, I just got an updated ETA on the grilles and remaining tweeters yesterday. I updated the order list in the initial post with another color code. Looks like we should be able to get every set delivered by the end of the month.
#220
Nice Improvement,...worth the price
Nice job Nick on the packaging and other attention to detail. Received my shipment Saturday and installed today. Your video explains it all and my installation was quick and painless,...unless you count the speaker connectors. Initial impressions are very positive. Thanks for the great job!
#221
You are stating that the surround option is horrible, right? And not that it is horrible that you have to forfeit the surround option.
#223
Platinum Sponsor
Shoot me an email if you haven't already. nick.akin@musicarnw.com
#224
[QUOTE=1 Definitely thoughts... and some R&D in the works. Working with factory amplifier power and the lack of a real EQ, we need to make sure whatever is done there is a worthy improvement. I want to have a solution, just need to take the proper time to be certain it's the perfect one for that application.[/QUOTE]
Looking forward to this if you can make it happen!
#225
My $0.02. Mine came in over the weekend. Put them in today and the sound is great - Thanks Nick.
Regarding the connectors in the old tweeters - yes it is difficult in getting them out but here is what I did. After pulling the old speaker up, cover the dash with a cloth, press down on one end of the silver metal strap holding the tweeter in the cover. This will release the tweeter. You will see a small hole that was covered by the strap. Use a very small screwdriver (mine was 1.8mm wide) and work the connector out. Regarding the hex bolts- just wiggle them back and forth when putting them in. That will insure that they are centered.
