991.2 PCM SD card question
Im using a 32GB SD card in the PCM witch is only filled up to about 15GB of MP3 files, but the system doesnt show all the music. what is the maximum capacity of the SD card that the PCM can read? should I use two smaller capacity cards instead?
Check out this thread:
https://rennlist.com/forums/991/8447...PsychicDreamer
The PCM holds 40GB I believe. Perhaps try a USB flash drive rather than an SD card, I had good results with a SanDisc 32GB.
