Stuff that's weird about the 991.1
There are definitely some weird automatic things with the car. What I get in my 911-50, before i start it sometimes I hear the parking brake motor do a little buzz. Any idea what that is?
"...would benefit from a dose of 5th to regain speed, a gear that's located somewhere between 7th out on its limb and the spring assisted 3rd. I have to admit to picking the wrong one several times, not helped by the otherwise handy gear indicator in the rev counter that displays a blank until the clutch is fully home."
As for first, my car will not show the indicator in 1st until I have released the clutch and I am moving.
GregD's quote above does not make sense, it is absolutely impossible to shift from 4th and accidentally end up in 7th. There is a lockout mechanism designed in the gearbox that will not unlock until you have engaged either 5th or 6th. I found this to be excellent as I track my car and hit 5th quite often. Depress clutch, pull out of 4th, push shifter as far to the right as you can, push shifter forward into 5th. Very easy to do and doesn't require any concentration - as it should be on the track
Is normal for the windows to come down a notch when you open the door. In that way, Porsche makes sure that the window doesn't get stuck in the rubber and you can open the door easily.
Regarding the fan setting, try leaving the fan setting were you want it to be the next time you jump on your car and make sure to save the setting by pressing the key button locate on your memory buttons on the left door. Next time you get into your car, the fan setting is going to be memorized and start the way you want.
I've read from one of the old experts here that the wiper jump is to keep them from sticking like plenum said. I wouldn't be surprised if the window indexing is also to keep the window and the window seal from sticking together if that door isn't opened for a long time.
Our Cayenne Diesel does the same thing. When you open the door, it starts clicking and priming stuff. Then when you turn ignition on but don't start, it does more of the same.
In addition, when you shut down, about 30 seconds later there's a weird growling kind of pumping noise. Real low frequency. I think it has something to do with the AdBlue because I've never heard a non-diesel do it. But i've heard other diesel loaners do it.
Gear shift indicator: My car is a late 2013 MT, first gear is a little different (more later) but the other gears will show up on the indicator as the shifter moves through the gate, before the gear actually engages and well before the clutch is released. That being said the car must be rolling at proper speed. I did this test, ran 2nd up to 4K, depressed clutch, then very slowly guided the shifter out of 2nd, across neutral, and slowly into 3rd watching the indicator the entire time. My car behaves as if there is a switch near the gate path just outside of neutral, when the shifter crosses that path the indicator changes appropriately.
7th to 5th downshifts just require you to return to neutral a bit to activate the lockout. It's an easy motion to learn, easier than heel and toe-ing. 6th to 5th, where you CAN get 7th gear, is what I'm still learning to do smoothly.
Received 1,542 Likes
Window indexing - first introduced on the BMW 850 IIRC - is primarily to reduce stress and wear on the window lift and guide mechanisms that result in 'floppy window syndrome' with frameless windows after a while.
Now it would seems that the results are split: for some people it works like on my car, that is "too late to be useful", but for 2 of you it works based on the gate (super useful).. I'd like to understand why, model year, software version ??? because the indicator would be super useful if it triggered based on the gate position and not on the clutch... Interesting... I'd love to have that feature ! I don't need the gear indicator to tell me which gear I'm in because muscle memory does that for me. But I'd love to get a preview with the clutch still not let out, to avoid accidental downshifts why I'm getting accustomed to 7th (which I'm avoiding religiously).
The Porsche engineers evidently decided that there was a need for fan operation on start. No mater what you do with the settings, the fan will operate when you start the car.
We just picked up our 2014 S and I noticed the passenger window going up/down as well. The oil smell is normal in 911's. I do have the same problem with the parking brake though. I'm starting to get used to it
Gear indicator comes up on mine as I lift the clutch - nothing before.
didn't know I could switch off the annoying little upshift triangle (I'll decide thank you....that's why I bought a manual). That will be gone by the end of the day :-)
Parking brake is also counter intuitive for me and I still have to think carefully each time I press it and often get it wrong (it's not a DD for me).
