Brake Pad Change
Old 10-09-2016, 08:24 PM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,116 Likes on 666 Posts
Default Brake Pad Change
Do you have to remove some brake fluid from the master reservoir and leave the cap open when using a brake pad spreader to open the pistons when changing brake pads?
Old 10-09-2016, 08:52 PM
Sidvicious7
Sidvicious7's Avatar
It all depends on your current level of brake fluid in your reservoir. I removed just a small amount when I replaced my brake pads to avoid an over flow last year.
Old 10-09-2016, 10:47 PM
008's Avatar
No, they wouldn't fit when new then. Unless it was grossly overfilled.
Old 10-09-2016, 10:49 PM
StormRune
StormRune's Avatar
I agree with Sid. If it is at max you'll want to remove some in any case since the new pads should put you above max. Below that you'll need to keep an eye on it to make sure it doesn't overflow. I'd recommend each time you finish a caliper, you pump the pedal to push the pistons back out on the the new pads. That will bring the fluid in the master back down some so it is less likely to overflow on the next one. If you spread the pistons on all of the brakes before you pump the pedal to seat them you're more likely overflow the master.
Old 10-09-2016, 11:56 PM
BradB
BradB's Avatar
I change pads and flush fluid on my 991 brakes several times a year (track days) and never pull any fluid out of the master cylinder reservoir prior to pushing back the pistons. I can take out thin dead pads, push back the pistons, replace with all new pads and not have an issue. At least that's my experience every time.
Old 10-10-2016, 09:09 AM
991carreradriver
991carreradriver's Avatar
+1
Old 10-14-2016, 06:51 AM
Porsche_nuts
Thanks for all the replies. Very helpful.
Quick Reply: Brake Pad Change
