Detailing/Cleaning supplies
#106
deleted
#107
#110
Just checked again and it's current for another 15 hrs. Not sure of the problem but here's the current copy.
*20% Off Coupon Code FRIDAY20 valid on in stock items. Not applicable on previously placed orders, custom or special order items, extractors, air compressors, BUY ONE GET ONE, VIP Special, car covers, polishers & polisher kits, vacuums, Kreepstool, FlatStoppers, garage flooring, gift certificates, bulk and case pricing, complete wash systems or any item as noted on product page. One coupon code per order.
*$5.95 Flat Rate Shipping applies to orders with ground service within the 48 contiguous United States. Regular shipping charges apply to garage flooring and mats, air compressors, and carpet extractors as noted on those products. Regular expedited charges apply.
#112
I have the same interior which has special needs. First off leather is either "A" or "P" - which refers to Aniline (non coated) or Protected (coated leather what is found in 99% of interiors).
Most over the counter leather products are not safe to use on A surfaces. I use and recommend the LeatherMasters Product Line - which thankfully indicates which products are suitable for which surfaces. They're customer support is also very good so if you have any questions, I would call and let them take you through the process. It's simply to use the products just there are 3-4 steps and you need to let it dry in between applications - so it takes some time.
The good news is that I only clean the interior 3-4x per year. On a weekly basis I used a damp microfiber towel and simply wipe off the surfaces. After 3 years my interior still looks brand new.
General Cleaning
http://www.leatherworldtech.com/Leat...lmlcbun250.htm
Stronger General Cleaning
http://www.leatherworldtech.com/Leat...mslcbun250.htm
Dye Transfer Stain Removal
http://www.leatherworldtech.com/Leat...r-p/lmldtc.htm
General Cleaning
I've never seen a car with "A". Its all coated so conditioner only changes lustre and smell. Good post. Thanks for all the info.
#113
What do you guys use to clean? Sponge ? Chenille microfibre mitt?
#115
Auto Geek Discount.....
#117
Addys Daddy. Just wanted to thank you again for your various tips. Just did the leather interior with leather masters products you recommended a few weeks ago and the leather looks so much richer now. Thanks!
#118
Question on overspray of convertible roof protectant: I got some Porsche protectant spray on the glass. You can't see it, but can feel the sticky residue and it picks up micro fiber. What is the best way to safely clean it off? Thank you!
#120
You can use 1:1 rubbing alcohol to water mix or this
http://www.autogeek.net/menzerna-top-inspection.html
