Question on Front Wheel Offsets - how far from stock ET is acceptable or safe?
Hi all,
I am trying to decide on a set of aftermarket wheels, and have noticed that most aftermarket wheels for P-cars use smaller positive offsets (reduced ET), which I think is to push the wheels outwards for a more aggressive appearance. While this may be fine for the rear wheels, I would think this would compromise steering geometry on the front wheels - impacting the scrub radius, steering feel, etc.
Eg. stock front Carrera 991 wheels are 19x8.5 ET 54
Many aftermarket wheels use ET45, say - which is almost 10mm shift of the wheel/tire centerline to the outside. I'm certain the factory designs their wheel specs and steering geometry for a reason. I just don't know why the aftermarket does otherwise, or if it indeed matters.
Does this create noticeable problems with either of:
- steering feel/effort, tramlining, kickback
- turn-in responsiveness
- increased sensitivity to wheel imbalance
Let me know if anyone has noticed any adverse effects on steering due to aftermarket front wheel offsets >5mm say from stock. Is there any tradeoff to be concerned about?
Thanks,
- Sanjeev
Thanks,
- Sanjeev
Hello
Thanks for your reply. Seems like a 5mm spacer is an approved configuration. Any experience on whether the steering feel is different with >5mm offsets on the front wheels?
Thanks,
- Sanjeev
Thanks,
- Sanjeev
