Help me diagnose please
Hello RL,
I wanted to see if you could help me diagnose a possible problem.
The Car:
I recently purchased a 2012.5 CPO C2S. It's a 7spd MT, with not too many fancy options (which was the way I liked it) and about 24K miles. It has the standard PASM suspension, on the standard 20" wheels and factory PZero tires.
The (possible) problem:
I was taking the car for a hard drive through the Angeles Crest canyons this weekend. The car was performing like a champ, and I was really enjoying the drive. On the return drive (which is largely a downhill ride), I experienced car bumping around far more than usual. My first though was that perhaps I had blown a tire, to the point where I eventually pulled over the check. The tires were fine, so I jumped back in and kept going. Still, the car felt strange.
Since then, I've been driving the car, and it largely feels normal, but it does feel like the bumps are noisier than usual. Hard to describe here, but bumps feel like they're making a "ka-thunk" sound vaguely towards the rear of the car. On a smooth road, the car is as quiet and smooth as can be.
I tried to go back to the canyons on Sunday late-afternoon, but ran into so much traffic that I wasn't able to get enough speed to see if it's hard driving that causes the bump and "ka-thunk" noises or not. Please note, that I can't seem to tell any difference if the "Sport" button is turned on or not. But, it was on during my hard canyon drive.
The context:
I've owned several "performance" cars including an RX7, an MR2, an E36 M3, and an E46 M3, several of which were significantly lowered so I'm very familiar with bumpy rides. In general, I'm amazed at how comfortable the ride is on the 991 considering how capable the car is. Also, I wouldn't by any means consider myself an automotive hypochondriac, but I'm questioning myself this time.
The question:
What do you all think? Does it sound like I'm imagining things or did something relatively subtle break? Thanks for reading this super long thread and thanks in advance for your advice
The Car:
The context:
The question:
Maybe high tire pressures or P Zeros that need to be swapped out?
Jim
Jim
So if the feeling is consistently rhythmic and speed related that would lead me to believe that it's rotating mass related and it sounds awfully similar to what happened to me on my 335i. There ended up being 4 large bubbles on the inner sidewall of the back right tire and it was causing the car to vibrate at speed. Might not be a terrible idea to have the alignment/tire pressure/tires checked.
Received 5,388 Likes
As for the tires pressures, you may have worked them, and heated them up on the way up the canyon, then on the way down, they might be a bit (1-2 PSI) over inflated from optimum. Don't let em get much over 40-42 hot. 40 is pretty ideal (hot).
Thanks everyone for your advice. I went ahead and lowered my tire pressure to comfort settings and was pretty amazed by the difference.
However, I don't think that tire pressure was quite the "problem". The outside temp on Saturday during my canyon run was probably around 100 degrees, so I do wonder if I may have overheated my tires.
Does anyone think it might be suspension related? The harsh hits seem to be more harsh than ever and make a "thunk" like sound.
Thanks all.
Thanks all.
Thanks all.
Thanks all.
Thanks all.
Thanks all.
Also remember if your tires were significantly over pressure this would impact high velocity compression cycles of your shocks, since the effective spring rate of the tires (over inflated) would be higher...
If the problem is still manifest, its a h/w problem, if its gone, then it was s/w (tire pressure etcs)
Thanks all.
Thanks all.
I recently had a "thunk" coming from my rear suspension. Brought it in for service, turns out it was the sway bar clunking away.
OP might also try driving with PASM in "normal" and "sport" to see if the frequency of "thunks" changes with this setting ...
