991 wheel offset questions, thanks all...
have a wheel question, will the below offset work on a 991 narrow body car? I have many people suggesting yes and others not sure. I am selling these wheels and have someone wants them if they can work on a 911 narrow body car. Thanks all... input on fitment greatly appreciated...
Front Wheel: RS128 8.5JX20" ET 53mm
Rear Wheel: RS128 11.0JX20" ET 58mm
here is my thread with pics...
https://rennlist.com/forums/parts-ma...w-pirelli.html
Rear is a little aggressive (58 vs about 70), but it should work. Some narrow-body 991 owners end up running spacers, so these would eliminate that need. Won't work well for a 4S/GTS/widebody.
-ty
-ty
Yes, they will work. But....
Narrow Body OEM specs are 8.5Jx20 ET51 front and 11Jx20 ET70
You're going to be 12mm more aggressive rear and 2mm front. Throw in 10mm spacers in front and they will look flush. It will look even better if the 991 lowers 1/2". Also, ensure the center bore is 71.6mm (997 and 991 have the same center bore).
I actually think the OEM set needs 10mm spacers all around anyways, so this would look flush.
