Getting PSE! Anything I need to know? - Page 3 - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 09-09-2016, 11:34 PM   #31
bittrl1000
User
Quote:
Originally Posted by STG View Post
They look very similar, but not the same. They don't fit perfectly.
I just did the install myself a couple months ago. I reused my non PSE tips. I can't say that the PSE tips are 100% the same, but my non PSE tips installed perfectly on the PSE.
bittrl1000 is offline   Reply With Quote
Old 09-09-2016, 11:37 PM   #32
STG
STG's Avatar
Quote:
If you look under your car, you'll notice the inner tip (opposite the clamp side), will be short by like 1/2" from pressure fitting. There will be a gap from the center muffler pipe to the tip.
See left side ^^
STG is offline   Reply With Quote
Old 09-09-2016, 11:41 PM   #33
bittrl1000
User
There is a gap, but it's the same as the gap that existed before I installed the PSE.
Old 09-09-2016, 11:45 PM   #34
STG
STG's Avatar
There is no gap with the right tips on S exhaust or PSE.
See pics above. The cupped pressure fit opposite the clamp side fits tight and snug on S exhaust and PSE.
The PSE tips are a bit longer there to get the correct fit. The S tips are shorter on the one side when putting them on the PSE.
Old 09-09-2016, 11:52 PM   #35
Archimedes
Super User
Archimedes's Avatar
STG is correct. There is no gap with the PSE tips and there is with the stock tips. My dealer showed me the difference when they did the install. Get the PSE tips if you want it to look perfect.
Archimedes is offline   Reply With Quote
Old 09-09-2016, 11:52 PM   #36
STG
STG's Avatar
Te left side here is different in length between two tip styles. Also, different inner barrel design and outer chrome finish.
I had my PSE tips ceramic coated as pictured.
Nobody, even Suncoast could give me accurate info on the differences until I compared myself.
Old 09-10-2016, 12:00 AM   #37
bittrl1000
User
I don't know what to tell you. The non PSE tips installed on the PSE just like they were installed on the non PSE exhaust. With both exhausts, inner tips do not make physical contact with the pipes from the side mufflers. Depending on how far the tips are pushed onto the outer pipes, the inner tips can have gaps both because of the smaller radius of the tips, and front to back.
I will try to upload pics I took of how the non PSE tips installed on both the non PSE and pse exhausts.
I think the more relevant point is that the non PSE tipse can be installed on the PSE with no issues. Again, maybe there is a slight difference between the tips, but it's not big enough to make a difference.
Old 09-10-2016, 12:07 AM   #38
STG
STG's Avatar
If one sees the male/female shape on the non clamp side (as pictured above), the cupped center exhaust pipe off the PSE fits into the exhaust tip.
Me personally, I want the right fit.
Will the non PSE tips go on?? Yes, they will clamp on but with a 1/2" gap on the one side. I prefer to have my exhaust fumes exit the tips and not leak out under the bumper when not moving.
Just stating the facts for those wanting to know the differences.
Old 09-10-2016, 12:18 AM   #39
dimok
User
dimok's Avatar
Thanks STG, very helpful as always.
dimok is offline   Reply With Quote
Old 09-10-2016, 12:25 AM   #40
STG
STG's Avatar
Quote:
Anytime. FYI: Torx size is E12 for tip bolt that clamps over the right side. That side (outer) exhausts the side mufflers behind the rear wheels, and the inner tips exhaust the center muffler.
Old 09-10-2016, 12:30 AM   #41
bittrl1000
User
In both these pics, the tips are stock.
This first pic is with the standard exhaust obviously.
This pic is with the PSE.
The gap is almost identical. If it's smaller on the PSE, it's because when I installed the tips onto the PSE, I pushed them further on before I tightened down the clamp.
Again, all I'm saying is that the stock tips install onto the PSE just like they were installed on the stock exhaust. Please note that I'm not saying "the stock tips install onto the PSE just like the way the PSE tips install onto the PSE". I won't try to argue that the PSE tips are identical to the stock tips, because I never bought the PSE tips.
I don't have a problem with a little gap, because that's the way my car came from the factory. I assume that if a slight gap is ok with the stock exhaust and tips, then it's ok with the PSE.
Archimedes said to get the PSE tips if you "want it to look perfect." I'll accept that there is a slight difference in the dimensions of tips. But the only way for someone to see that difference would be if they crawled under the car. Otherwise, my car looks exactly the same as it did before I installed the PSE.
I'm arguing that there's effectively/mechanically no difference in the tips, no difference in appearance (besides the obvious chrome vs polished), and so folks should consider saving the ~$1,200 cost of the PSE tips.
Old 09-10-2016, 12:30 AM   #42
STG
STG's Avatar
Old 09-10-2016, 12:35 AM   #43
STG
STG's Avatar
Bittrl1000, get those tips refinished!!
Old 11-25-2016, 12:49 PM   #44
07CarreraS
07CarreraS's Avatar
For PSE, My dealer here in Tampa is saying 4 1/2 hours labor for around $650 total installed on my 05' C2S
07CarreraS is offline   Reply With Quote
Old 11-25-2016, 12:59 PM   #45
daberlin
daberlin's Avatar
Quote:
Suncoast has the kit on sale for $2195 right now; not sure if it's a Black Friday sale or otherwise. With your $650 to labor to install, that's a heck of a price for this great upgrade!
daberlin is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
FS: Carnewal PSE manual/remote control FLGT 997 GT2/GT3 Forum 12 03-15-2017 07:08 PM
PSE on all the time Giorginetto 996 Forum 15 11-15-2016 05:57 AM
FVD tune on 981S...PSE cackles seem less pronounced Georound 987 - 981 718 Forum 3 06-05-2016 07:15 AM
991S - no PSE - Sharkwerks vs adding PSE sound? 1atom12 991 2 04-14-2016 05:04 PM
PSE retrofit DIY SB 991 2 12-09-2012 09:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
