Spoiler deploys to different heights
My spoiler goes one notch higher when I exceed 80mph, and then goes back to the regular open height when I go below 70mph. In both conditions, I had the sunroof open and the spoiler switch "on" so the spoiler was extended to regular height regardless of speed. I can see the height change in my rear view mirror when I exceed 80.
I tried playing around with all of the settings tonight in the garage and I couldn't get the spoiler to change height. If the sport/sport+ changes the height or the sunroof, then it must be only when it's moving or maybe at highway speed.
Yeah the higher sunroof setting only happens when the speed logic is valid (77mph exceeded without dropping below 50), so if you manually deploy it with the sunroof open, it will go to normal until you exceed 77 and then go back down to the normal setting once you slow below 50 again.
Or on the .2 it goes up and down to control cooling air for the little engine too.
