991.2 GTS'es are coming as 2017 MY, 3.0L tt
Old 04-10-2016, 03:02 PM
  #61
NoGaBiker
NoGaBiker's Avatar
Originally Posted by Jabs1542
Not exactly, I had a base 996 (C4) that was a 3.4L engine (300 hp). I think the engine differences started showing up in the 996s.
Nope, you had a 1999, 2000, or 2001 996 with the only engine available in the Carrera, the 3.4/300-ish hp. There was no S model and no other Carrera engine option. In MY2002 the 996.2 was released with the 3.6/325 motor. In 200? the Carrera 4S was released as the only Carrera S, and it offered Turbo wide-body and some mechanical bits, but still had the same 3.6 as the narrowbody, non-S Carreras. This was a carryover from the 993 "S" models, Carrera 4S and Carrera 2S, which were Turbo-look but had no difference in the motor.
Old 04-10-2016, 08:02 PM
  #62
subshooter
subshooter's Avatar
Received 2,137 Likes on 978 Posts
Originally Posted by AC SATCO
I spend most of my time in the 991 GT3,RS, and R forum but took a stroll in here today. I must admit I got a lot out of this thread and how people feel about what Porsche us up to. I have a 997 GTS and A 991 RS. I'm obviously a NA guy. I agree with most here that the new GTS needs a little more than larger turbos to command the premium, I also think the 991.1 GTS is "the car to buy" if all .2 will be turbo. Heck I might look at them to upgrade my 997.2 GTS-4 cabrio if it'll be the last non turbo. Either way thanks for all the info I learned plenty.
Uhhhhh..... I can't tell by your signature block if you like Porsches or not. Can you elaborate please?
Holy crap!
Old 04-10-2016, 09:06 PM
  #63
Larry Cable
Larry Cable's Avatar
Received 3,419 Likes on 2,235 Posts
Originally Posted by TorqueChap
Nice scoop Larry Cable
Some day I'll have to ask you how on earth you found this document. V-e-r-y resourceful.
I cant tell you my sources ...
All I can say is that the ARB report merely *confirms* their assertions about the 2017 GTS
Old 04-10-2016, 09:13 PM
  #64
Larry Cable
just think, the GTS with 450bhp/400lb/ft, and all that low end torque, add in PDK, SC, PASM-S, RWS ... that is
going to give the existing 991 GT3 a run for its money ... especially on tracks where low end torque
benefits low speed corner exits ... there might be quite a few GT3 owners embarrassed by the new GTS
which I think certainly means that the .2 GT3 will have the RS'es 4.0 500 bhp powerplant!!!!
frankly if you are in the market for a 991.2 I would be calling my dealer and putting a deposit on a 2017 .2 GTS ... the wait will be worth it!
Old 04-10-2016, 10:20 PM
  #65
LnC993
LnC993's Avatar
Now you make me drool over the 991.2 GTS..
I think this up coming turbocharged GTS is going to be interesting. It will be the most powerful turbocharged RWD 911 variants besides the GT2 and also the most powerful turbocharged 911 that offers a manual transmission.
Old 04-10-2016, 10:30 PM
  #66
Larry Cable
Exactly! It's the 991.2 variant to wait for!
Old 04-10-2016, 10:56 PM
  #67
Jack F
Jack F's Avatar
Originally Posted by tejstar01
And I bet the GTS will have exactly 30HP more as it always has so 450HP will be the ticket it seems!
Since the 991.2s was dynod at 450 then 480 for the gts. That would be substantial!
Old 04-10-2016, 11:25 PM
  #68
Larry Cable
Old 04-11-2016, 12:21 AM
  #69
Dodaleca
Dodaleca's Avatar
People using the Cobb dyno test 383 BHP rear wheel and getting to 450 flywheel assuming 15% powertrain loss.
https://rennlist.com/forums/991/9263...l#post13151508
I'm now thinking that rather than looking for a good used TT that a 450 BHP GTS 4 manual might be the way to go if I can afford it, more modern with a longer warranty, new car smell, built the way I want it, ... plus likely similar performance up to a 997.1 TT in some aspects and better it in others (handling with RWS).
If you want the NA exhaust soundtrack then the assumed turbo 3.0 991.2 GTS still might not be the car for you.
Old 04-11-2016, 11:58 AM
  #70
jimbo1111
jimbo1111's Avatar
Im not a fan of DynoJet dynos. They tend to inflate turbo engine output. Id like to see the 991.2 dynoed on a Mustang dyno. Cobb has a dyno run of a stock 991.1 on Mustang dyno posted on there site that produced 370whp. Would be nice to see a comparison on the same dyno.
Old 04-11-2016, 01:25 PM
  #71
Stil_1
Stil_1's Avatar
Would the GTS or rather any 911 still have a 15% drivetrain loss? I thought it was due to the drive shaft plus the transmission that contributed, but doesn't the 911 not have a long driveshaft that would absorb torque, just gears from the main engine to transmission then back to the tires?
I also have seen modern RWD front engine cars reduced their drivetrain loss down to 11-12%, so maybe the GTS would be less than that given it's pretty modern.
Old 04-13-2016, 11:51 AM
  #72
917k
917k's Avatar
Cool info - thx Larry!
Old 04-13-2016, 01:33 PM
  #73
Larry Cable
agreed
Originally Posted by STG991
Exactly. Very predictable.
Originally Posted by NA430GTS
Good find Mr. Cable. I'm a bit disappointed that the next GTS will be turboed on the same 3L engine as the base and S models. Basically you are paying more for larger turbos as you move from base to GTS. Porsche is really making it hard to "upgrade" down the road from my NA GTS.
I know - although 450 bhp on tap with lots of torque ... could be addictive!
anytime! - I expect the .2 GTS be the car to wait for ...
Old 04-14-2016, 09:57 PM
  #74
STG
STG's Avatar
Larry is DA MAN
http://www.carscoops.com/2016/04/con...elift.html?m=1
Old 04-14-2016, 10:12 PM
  #75
TorqueChap
TorqueChap's Avatar
+1. Props Larry.
Quick Reply: 991.2 GTS'es are coming as 2017 MY, 3.0L tt
