Steering Wheel Off Center After Alignment
I recently had an alignment done and the steering wheel is now off-center (tilted clockwise when driving straight). I have the alignment print out and all of the specs look good.
How would this happen? Did the tech not straighten the steering wheel when performing the alignment? I was told to bring it back in and it would take 10 minutes to straighten the steering wheel. Are they able to straighten it without doing the alignment over again?
DJ
'14 C2
DJ
'14 C2
They will need to change the toe setting
Received 5,388 Likes
Dealership or indy shop?
you can have steering wheel straight with car off center. or vice versa...
go back and have them adjust.. the lenght of the tie rods stays same but they just make one shorter.. one longer to make steering straight
generally theirs a lock you place on steering wheel.
nothing is wrong w/ alignment its just not centered as it should
generally after alignment car always pulls right too cause the shape of the road... go to a center lane and see how it tracks...
Thanks, the alignment is good, the steering wheel just isn't straight when the car is tracking straight (it's obvious enough that it bothers me). If they adjust the toe, won't that affect all of the other settings and require a new full alignment?
This was done at a competent dealer. Thanks
How much did they charge?
I don't get it - you would think tech would take car out for test drive and would notice this immediately. And to the OP, didn't you notice this immediately when driving car out out of the dealership?
I have a 2017 718 Boxster S I replaced the oem steering wheel with aftermarket Carismo steering wheel, this was done at a local reputable shop but after a day I noticed the steering wheel is slightly off to the right when the car is tracking stright. I did not have issues with alignment or steering being off center before the wheel change.
Is it because they didn't put the steering wheel on straight ? Or will a simple toe/alignment adjustment fix this? Should I have them take off the steering and out on again?
