COBB Accessport Now Supports 991 Carrera, Carrera S, and Carrera GTS
#301
Frank,
Thanks for the info--it insures domestic tranquility. In reality my wife is a gem and is very accommodating of my obsessive behavior with regards to my P-car. I really don't want the Accessport in the cabin.
#303
NEW REVIEW.
So I purchased the AP3 and installed this weekend. I must say I was a bit skeptical about the performance and somewhat concerned about the install, even though it appeared easy.
Install: Took about 7 minutes from start to finish. No surprises, no glitches and as advertised. Actually took longer to put the damn cover back on the battery area. The hardware/software interface is intuitive, but given my age and aviation background I have seen all generations of software and hardware, some of which should be outlawed. Never read the instructions and mastered the interface in about 5 minutes.
After install:
This Stage 1 93 OTS tune more than met my expectations. Quite frankly, it is like driving a completely different car. I have only used on the street and here are my first impressions:
1. Totally smooths out the lower power band.
2. Noticeably more low end torque.
3. My engine is quieter now. In fact, I am wondering if I have a recent bad COV that controls the cabin noise.
4. Rev's are quicker, noticeably quicker.
5. Car is seat of the pants quicker.
I will be tracking this coming weekend and will provide a review after the event. Definitely worth the $$$ for the performance increase. In addition, I should note that I have an AWE exhaust on my car and it seems this combination has really harnessed hidden HP and Torque in a 3.4 NA PDK. I am fairly sure that I am running 0-60 at less the 4. The track will let me know for sure -- stay tuned.
After install:
#304
Jabs1542 - you're right, any production change comes at a cost. I wonder if the differences in OBDII plug location are related to model differences - mine is a GTS and it came with at least one item that the service manual says is GT3 only - the steering spoilers. Kind of a trip to think this thing might have been made on the GT3 production line
#305
#307
Basic Sponsor
NEW REVIEW.
After install:
After install:
Thanks for the review and good to hear the install went off without a hitch! Give us your impressions after the upcoming track day and after you get a few more miles on the tune.
Thanks!
~Jared
PORSCHE EXPERT GROUP - TIM | GRANT | HJ | ANDREW | JARED
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE |CONTACT US
#309
yup that's exactly what it will do, many of the earlier GT3's had similar components which make a difference to the front brake temps when on track.
A common 'upgrade' for the 996/997 GT3's were the cup car brake ducts ...
#312
On track experience, PDK Sport Plus mode:
- Rev's were quicker, similar to street.
- Power band at high rev's was awesome. Much better performance than without the tune.
- Speeds were higher on straights than without the tune.
- Oil, engine and water temps were as expected.
- No detonation
- Low end torque much improved.
- Smoother throttle modulation was very noticeable and most helpful in the corners.
After I arrived home, I emailed two data logs to COBB for analysis. Their response was timely and they assured me that all looked good. They discovered one anomoly, which required my input. They found a pedal position that was not consistent with throttle angle. Turns out, that I remembered the SPASM kicked in on a an aggressive track out and abrupt turn. This confirmed what they viewed in the analysis as normal and not an airflow issue.
There is one thing that I have noticed and am curious about. The AP3 unit shows various readouts that one can choose. I noticed that there is an inconsistency with oil temp and pressure with the car gauges. For example, the AV3 unit shows a higher oil temp until full operating temp is reached, then they sync up within a few degrees. The oil pressure indicates much higher than the gauge all the time. I just am assuming that the ECU transmitting direct to the AP3 is far more precise and responsive.
After two track days, I remain pleased with the tune and the customer support.
#313
#314
All these good reviews is gonna force me to buy that darn thing!
#315
Yes, I'll be buying one once I get my car baselined. I'm really interested in the smoother throttle modulation. The throttle gets very twitchy when tracking out above 5000 rpms, plus I have a definite bump in my throttle curve where a sudden surge of power kicks in (probably around 6000) - you would think I was wiggling my toe or forcing the throttle down harder. Really want to get this smoothed out.
