CS/GTS BBK with GT3 Size Rotors
Former Vendor
RacingBrake is pleased to announce following rotor kits are now available for upgrading your your CS/GTS to GT3 rotors (380mm) with stock calipers.
This upgrade not only can improve the brake performance but also can make your CS/GTS looks more muscular than stock rotors.
https://racingbrake.com/POR.991.cs.irk.380-380-1
They allow you to upgrade your stock size to GT3 by retaining the use of your stock calipers (required spacers and longer caliper bolts are included in the kit)
Front rotors: 380x34mm (OE=340x34)
Rear rotors: 380x28mm (OE=330x28)
Essentially you would be upsize the rotor to same size as GT3, except we reduced the thickness in the rear by 2mm in order to fit the stock rear calipers (28mm max).
Front calipers are known to have asymmetrical legs (like 997 TT), no other brake supplier than RB was able to make this upgrade kit available.
However with our technical competency we were able to develop a pair of asymmetrical spacers for a 100% bolt-on installation with precise fitment.
Related discussion: GTS brake upgrade to GT 3
Another valuable brake upgrade kit proudly presented by RacingBrake
Former Vendor
Front set up with (380x34)
Below pictures show the CS/GTS Front caliper on 380mm rotor installed with RB caliper spacer.
Both Center Lock and 5-lug are available.
Former Vendor
Rear kit
Rear set up (380x28)
Rotor Wt:
Rear has a deeper with iron liner for drum emergency brake
Top view
Rear view with spacer installed
Front view
Front view with pad detail
Side view
Rotor Wt:
Top view
Front view
Side view
curious about solutions for those of us with PCCB equipped cars?
Former Vendor
We have complete brake solution for Porsche 996/997/991.
Stock size rotor swap.
pccb replacement (discs only - re-sue hat, or whole rotor assembly hat & discs)
pccb conversion (converting pccb to iron)
Oversize brake kit (BBK) pccb conversion (converting pccb to iron)
Upgrade to big rotors but re-use stock calipers.
Complete brake kit.Whole system upgrade including calipers.
Please be more specific of your need with model/year so we can provide more detail.Thanks
Former Vendor
If that's the case we can design a "slanted" spacer kit to oversize to 380mm which is the same CCM rotor kit we offer 991 GT3's standard iron brakes upgrading to CCM rotors.
380mm Rotor Kit for 19" Wheels (Complete brake kit)
https://rennlist.com/forums/991-gt3-...l#post12113775
380mm Rotor Kit (Rotors only)
https://rennlist.com/forums/991-gt3-...19-wheels.html
991 GT3 Weight savings and costs
https://rennlist.com/forums/991-gt3-...and-costs.html
Can you confirm you have the same caliper as picture above (red calipers) with asymmetrical legs (slightly longer?) and the rotor sizes are 350mm Front and 350 Rear (similar to 997TT w/pccb).
require closer inspection of the part to determine that.
Former Vendor
That's usually the case (997, 991), essentially they are the same caliper but the color.
Yellow caliper = pccb
Red caliper= iron (std) brake
Porsche varies the caliper leg length for different rotor size, and if the rotor thickness is different the caliper offset also got adjusted accordingly.
No PDCC (Dynamic Chassis Control) is a dynamic ARB/swaybar, there is no interaction between the braking system and h/w and this system, nor should any of the component modifications interact mechanically or otherwise.
