Alignment question
Alignment question
So I had a bit of an odd experience today when I picked up my 911 from the dealer. I purchased the car on Tuesday after having a extensive PPI done on monday. I left it at the dealer so they could install a new steering wheel and add some tint. I picked it up today and on the way home at around 60+ the car pulled lightly to the right. Over 85 the pull was pretty dramatic. I took it back to the dealer and let them know what was going on. The service manager took a ride with me and agreed that there was indeed an alignment issue. He had one of the techs take it in the back to align the car. They provided the sheet below showing the new alignment. On the way home it still pulls pretty good to the right when over 75 (not as bad as before but still pretty bad). Any thoughts on what else I should check? Tire pressure is 34 on both fronts and 36 on both rears so I dont think it could be anything related to that. The car has only 5800 miles on it. Any thoughts or advice would be greatly appreciated. Feel free to tell me it's all in my head
Thanks!
Thanks!
I had a MY10 ptt before that pull to the left (RHD car) which I described as really bad. Alignment has been done but turns out was due to bad front left tires. Changed all 4 and all good.
I'm no experts on alignment,
From your sheet, everything looks pretty normal eventhough there are tiny bit of front caster differences and negative trust angle in which suggest a potential pulls to the right (due to front right has less positif camber and thrust angle is negatif = to the left which will pulls the car to the right).
Rarely, but I've seen one, the alignment machine itself is not "align". Put the car back on the machine and the reading must be the same. Not exact same number, but the same differences as before.
Received 3,877 Likes
If the car was out of alignment before it *may* have put a wear pattern into the tires that can only be remedied by a new set of tires. Ideally if you can swap wheels out with another owner for a short distance then you can tell instantly if its tires. If you bought it from a dealers (looks like you did) they could do this with another used 991 on the lot if they wanted to accommodate you. Make sure you are driving on roads without a severe crown on the blacktop as well. I can tell you with 100% certainty that Porsches do not pull to the left/right unless something is out of whack. I suspect it will be tires.
swap your left and right tire / wheels and see if the pulling direction reverses , to rule out a damaged tire carcass from prev owner bashing a deep pothole or glancing a traffic island at speed
I had a bad alignment once, had it fixed, still pulled bad though everything was in spec. Took it to highly regarded alignment guy. First thing he told me was to swap tires side to side. He was right. The bad alignment had worn the tires unevenly. New tires and it tracked dead straight.
Received 5,388 Likes
Yes - agree with Lex, that shows you need new tires at the very least.
Thanks everyone for the help!
