Loss of Tire Pressure ... Is This Normal?
Air is over 3/4 nitrogen. But pure nitrogen would do two things, the pressure would not deviate much under temperature changes, and the gas escapement would be minimized as the molecular rubber network wouldn't allow bigger nitrogen molecules to leave the tire (oxygen is smaller and about 16-18% of air).
http://www.getnitrogen.org/pdf/graham.pdf
Oh, and in regard to the original tire pressure question. While unlikely, a bad TPMS sensor could also be at fault. Easy to check though with a good tire gauge.
So I read this and thought, what is he talking about, how could nitrogen, with a slightly smaller mass than oxygen be a bigger molecule than oxygen (N2 v. O2, that is)? If anyone else is curious here's a "relatively" simple explanation - note though that it is from "getnitrogen.org" so give it whatever credence you think appropriate.
Received 1,542 Likes
The primary reason Nitrogen is used by races teams is that it doesn't have moisture in it. Air from your garage compressor has a lot of moisture in it. It's the moisture content that changes the pressure/temperature dynamics far away from pv=nrt (or whatever.)
I'll just leave this here...
http://www.tirerack.com/tires/tirete...jsp?techid=191
The reasons are complicated but can be distilled down to a few basic ideas. Not getting into the quantum mechanics of atoms - let's take as fact that atoms are overwhelmingly pure space >99%. As the atomic number (number of protons, and mass) increases the "pull" on the electrons increases disproportionately, causing the volume to contract and therefore become smaller. The above is only true for a set of progressively added protons. So take this explanation to be true only for N2 and O2.
Nitrogen is pretty close to 1 under all conceivable pressures. And yes, water deviates very badly. But I'll sell a bridge in Brooklyn to anyone who thinks they can get anhydrous nitrogen in their tires without the equipment that F1 uses.
Received 5,388 Likes
The primary reason Nitrogen is used by races teams is that it doesn't have moisture in it. Air from your garage compressor has a lot of moisture in it. It's the moisture content that changes the pressure/temperature dynamics far away from pv=nrt (or whatever.) I'll just leave this here... http://www.tirerack.com/tires/tirete...jsp?techid=191
The other primary reason is that N is a non flammable gas.
Interesting. 'splain please. A lot of organizations have a nitrogen tank, a regulator and an inline dryer and expect dry nitrogen out of it. I'm not buying your bridge but I might like a view from a distance...
All tanks have regulators, no open valves at those pressures are practical.
Inline driers are pretty much useless for a couple reasons. The desiccant they use (CaCl2 typically) is not as efficient as others but good enough IF the gas is passed over it more than once. The tanks that AirGas or BOC deliver are very wet. Same for other companies. Furthermore, the dessicants get inoperable quickly, being fully capacitated. Most consumer "organizations" probably are not concerned with changing them.
Nitrogen generators are better, but not much better (nevermind if nitrogen is being generated in humid environments).
You want dry N2? Pass it through a desiccant a few times at cold temperatures.
Hope this 'splains it. Let me know if you want the bridge.
I only use certified German air in my tires, and rotate it quarterly. Rotational mass is much lower and acceleration times and gas mileage greatly improved. The German air fully complies with the Ideal Gas Law and other stringent environment regulations, and is fully ISO certified.
What do you consider very wet? I'm looking at Praxair's spec sheet:
http://www.praxair.com/~/media/praxa...4631.pdf?la=en
what's 'wet'? 5 ppm? 1 ppm?
