Wheel Spacers
Wheel Spacers
I have a 991 Carrera 4 with 20 inch Classic II wheels. The wheels in the back are 305's and im looking to get the rear wheels flush with the fender. Anyone ever put on spacers and if so what size/mm should I go? Any pics would be great too. My options are 5mm (factory), 7mm and 15mm. Thanks
Unfortunately no. But check the link below for some pics.
https://rennlist.com/forums/991/8258...-on-991-a.html
7mm & 15mm w/extended bolts from Adaptec (made in USA). Notice the 7MM are hub centric w/flanges. Most 7MM I found were flat. About $250
If you get spacers make sure you get an alignment pin - makes the wheel easier to mount on the hub.
OEM 5mm Porsche spacers are another option...here's the details:
http://www.porscheownersmanuals.com/.../6/239/Spacers
Do you have PASM or SPASM on your car?
I have PASM and a 15mm spacer was too much, it stuck out too far - definitely more than Tony's pic shows. Tony has SPASM.
I went down to 7mm in both front and rear. The rear could probably handle a 10mm with PASM. I just haven't had the time to find out.
DaveGee
DaveGee
Johsmo,
I have a set of 7mm & 15mm spacers and lug bolts that I used on my Classic Sport II wheels. I went with aftermarket wheels that didn't require them. PM if you're interested in buying them.
J, If you do decide to go this route, save some $$ and contact Ski Porsche above or: Post # 108 https://rennlist.com/forums/991/842093-g-g-6.html
Received 5,388 Likes
